Trailblazer 302
    Sorry I havent gotten back to the boards in a bit, Ive been really busy. Thanks for all the information guys. Ive been bouncing back and forth comparing the TB302 and the LE's competiter brand, and Im sold, Im going with the TB302. Im picking it up in about 5 days.
    So Im gonna need a seperate tig machine to run tig?. If so I wont be able to afford it right now. At our school we clip the ground connected to the argon hose to the machine, and then screw our tig torches onto the argon hose. I didnt see any additional tig machine. Am I missing something here?
    If you want peace, be prepared for war!
      Like you said on the TB-302 for DC tig. It has lift arc and a couple of other tig features. For AC tig you would need a high frequency box.
      Hope to get a torch one of these days and try mine out on tig .
      Trailblazer 302
      Lincoln SP-135-T
      Hobart Stickmate AC/DC
      Smith torch
      Spoolmatic 30A
        Originally posted by F350Welder View Post
        What about the Pro 300 any input on that?
        Haaaahahaha,,,its a joke. Welds like ****.....
          usmcruz,
          The company I work for has 9 302G's and I own one. If you stay in the mechanical piping the 302 will be fine because the largest rod you will normally run is a 1/8" 7018 and few 5/32 7018.
          If you go over to the pipeline side you will have to run 3/16 & 1/4" 8010's unless you do utility work then you will run 5/32 6010.
          The engine is the weak link on these machines, I don't think they will last running the 3/16" & 1/4" rods all day. I have run a few of these rods and the engine didn't like it.
          The Trailblaser series are the best mutipurpose machines out there. I have made a lot of welds with a 55D and a 350D Trailblaser and they ran great.
          I had to make a couple of welds a while back with a rental machine and they brought out a Big 40D. It was sweeeeeeet!!
            Ahhh, so the box that miller sells is for ac tig, but if im doing DC tig I wont need anything extra besides the torch, argon hose with ground, and work lead right?. Sorry this is all new to me, and its allot of money going into this so I just want to make sure Im not missing anything.
            • #21
              Yes sir you are correct, hook your stinger lead to your argon hose, hook your ground clamp to your work set machine to straight polarity=electrode negative hook up your argon and get to work.
              • #22
                Thats the best news Ive heard all day thanks shortarc and BDJ. I was thinking I had to buy $1500 of extras. So if you guys dont mind me asking a rookie question, why would someone want to tig or stick weld with AC. I never get a straight answer from my instructors when i ask this question. They usually respond and say "Depends on whether you like to get electrocuted or not".
                • #23
                  Thanks for all the good info on the machines. I've wanted a diesel generator that can weld for a while. Just can't justify the price for the few times I'd need it. Really would prefer diesel to gas, I stock lots of diesel, no gas. Good info on the DC tig, never really thought about how that would be set up.
                  As for AC tig, its the way to go for alum. Don't know if I'd go to the hastle of AC Tig with an engine machine or just break out my mig and spoolgun for the Alum. Guess its more of a question of what you have vs how often you need to do it.
                  Any good reasons for diesel over gas for an engine machine? I mean other than a diesel will run forever. All my trucks are diesel and it seemed the way to go since I keep 250+gal on hand for them. Nothing like needing backup power and having no fuel. Been there done that with my small 4500 watt gen set.
                  • #24
                    Go to this page.
                    Then go down to where it says "lift arc" click on it. Even has a video to explain it.
                    Trailblazer 302
                    Lincoln SP-135-T
                    Smith torch
                    Spoolmatic 30A
                    • #25
                      Thanks brother will do!!
                      • #26
                        For the pipeline issue, it has more to do with the actual arc than the machines capability I think. The DC generators, like the lincoln 200D, have an arc that is designed for running cellulose rods vertical down. Pipe welding is a whole different world from what I've seen and heard.
                        Owner of Burnt Beard Fabrication & Welding Ltd.
                        BigBlue 500D
                        Millermatic 211
                        4' Box and Pan Break
                        IR compressor
                        • #27
                          I use my hf box with the trailblazer alot. Although its not a nice as a Dynasty or a Syncrowave, it really does a nice job. I was surprised about how much I get called for portable aluminum.
                          Miller Trailblazer 302
                          Miller 12 RC wire feeder
                          Miller HF 251D-1
                          Miller 175 wire feed
                          • #28
                            Is it possible to weld alluminum using DC?
                            • #29
                              Aluminum can be welded with dc elect neg but it's not a common practice. It would have to be extremly clean. You lose the cleaning action of the ac to help remove the surface oxides. I run a Trailblazer 302 gas also. Good machine The only limiting factor I have run into occasionally is the 200 amp AC output in tig mode.
                              • #30
                                Thanks for the info, but what would you need your amp settings above 200 on tig for?. At the welding school we would rarely go over 142 amps and that was running it hot, or are you talking about that welding alluminum would take more amperage using DC?.
