Welding Table
  • Welding Table
    I need help designing a flat welding table. I am a fence contractor who is tired of welding on the floor. I need to be able to handle all sizes of chain link and ornamental gates and panels. It must be easy to square up corners too. Any suggestions??
    Thank you
    Fast Freddie
    I would buy a sheet of 4x8' 1/4" steel and put 4 legs under it with cross bracing then just weld a couple of jigs on the top for your corners.
      That is what I did. I plan on building another when I finish my shop for the larger stuff. Make them the same and they can be put together for one big honkin' table.
      Don
      '06 Trailblazer 302
      '06 12RC feeder
      Super S-32P feeder
      HH210 & DP3035 spool gun
      Esab Multimaster 260
      Esab Heliarc 252 AC/DC
        Welding Table
        I weld large gates. 12' High X 20' or more. This is my problem. I also have to be able to reach the reinforcements in the middle of the gates.
        Fast Freddie
          Two tables with jack stands in the middle? When I had some stuff to do out of reach, I just hopped up on the table and took care of it. That would get old if I had to do a lot of it, though.
          Don
          '06 Trailblazer 302
          '06 12RC feeder
          Super S-32P feeder
            All my tables are the same height so i can move them around to do big stuff and still have the center open...Bob
              Here is the perfect solution. I call it the superman!
                I think this is the best idea yet.
                Fast Freddie
                  why not make several tables that can be configured to fit a project along with a small rolling stair to get to the middle of a really big job?
                  Millermatic 175
                  Spectrum 375
                  All kinds of Smith OA gear
