I'm working on building a pole barn and I want to have a beam running from the big door to the back of the building. I want to be able to unload material and parts at the door and be able to either sit them on a cart if they are really heavy or just wheel them through the shop on my 1/2 ton electric chain fall that will ride on roller dolly that will be connected to this beam.
I already have the beam I want to use and I wish it was a little heavier but it was free and I have been sitting on it a long time for just this purpose. It is a W10 that is probably in the 19 to 22 lb per foot range depending on which speck sheet you look at. I've already been called crazy for thinking about doing this but you have to understand considering what has been in use doing exactly the same thing as I am describing here for the past 30 years I can't see a problem.
The old system in the old shop was a small light weight 4X4 I beam that was hanging from the medal truss and connected at about 10' intervals with 5/16 bolts. The beam was butt welded in several places along the run with no other support. This worked for a long time but when I put up the rail in this building I want to at least make it look like someone had some idea of what they were doing along the way.LOL
Rather than just weld the beam in the middle where the most stress would be I plan on cutting one beam in half and making two splices where the stresses will be less. Some say weld it and forget it others say bolt it together with butt plates and some say do both. I have been searching the internet for weeks looking for information but it seems there is some sort of union the engineers have going that you have to somehow breach to find out anything. I'm a tight wad and broke on top of that so spending $150,000 to go to engineering school is not an option and it seems they want $1200 to $2000.00 to even give you the time of day.
As I said any heavy lifting will be done where the support beams are and I don't plan on lifting a 4X4 truck and rolling it through the shop. The most use will be to lift ends of stock material to hold in place at the mill to bore holes in or at the chop or band saw when cutting stock off. This tower will be constructed out of the same beam as the top beam material is and bolted to the floor on it's own footing. I can run support braces from the upright out to about 6' without being in the way. Also once the truss system is in place I can add an upper support system from the center of the beam back to the start of the beam both ways. I can also bolt it to the truss system if I need to.
Right now I want ideas on what would be the best way to make these connections without having to pay an engineer $1200.00 for him to tell me I'm nutz.
I don't have a copy of AWS D1.1 anymore. I had one at one time but somehow it grew legs and walked and I really don't have $500 bucks right now to buy another copy. Thanks in advance for all the wonderful information I know I will receive here it is very much appreciated.
