Welding Table
  • Welding Table
    I noticed some of your posts about welding tables and decided it was time to upgrade my little 3'x3' x1/2" table.
    I went to my local scrap Guy and picked up a 4' x 8' x 1" thick a36 steel plate for $190
    Only a slight bend in it. Anyways, I have some 8" I beams I cut to support and fully straighten the table out with but..... I am Out of beams to use for legs...
    What do you guys suggest to support a big heavy table like this? Scrap Yard is out of beams, and I dont want to shell out $$$ at the local steel yard.
    Basically, what would be strong enough to support 1500-2500 lbs when loaded?
    I was thinking 4" square 3/8" wall tube should suffice, any ideas?
    Voigt Precision Welding, Inc.
    Miller Dynasty 200 DX, Miller Syncrowave 250, MillerMatic 252, Hypertherm Powermax 45, Auto Arc Trailpower 8000,272+187 lb Peter Wright anvil, 120 lb Fisher-norris, and more! Buffalo drill press, Grizzly Horiz. Bandsaw, Edwards shear, Barth Shear, bantam mechanical ironworker, Hopkins fly press, Doall Bandsaw, brown and sharpe surface grinder.
    2007 Silverado 2500HD (tow vehicle)
    2000 Camaro SS (Race car)
    I would use 1/4" wall and would still be plenty, that tubing is very strong vertically. I want to build a similar table myself but I wanted a 5'X10'. Nothing like having a nice large flat surface to weld on. I have been in a search for welding platens or "acorn" table as they are commonly known but don't want to shell the big bucks. I think you have to run across a person who has one and try to buy it. Looking at used machinery businesses they are very expensive and all beat up. Lets see some pics!
    Modern Metalworking L.L.C
    Blissfiled, MI
    517-605-9481
    Miller Dynasty 350 Tig runner
    Hobart 3-phase mig
    Hypertherm 1000 plasma
    Mill
    Lathe
    Box break
    Shear
      I'll see if I can scrounge up some tube..... wish I hadnt brought 1/2 my cutoff's to the scrap yard a month ago....
      I'll get some pictures up soon, I need to find the digi camera... So far the table only cost me $190 + $30 for casters.
      On a side note, where can I find a humongous vise?
      I saw one on here that must have had 8" jaws, and weigh like 300 lbs....
      All I have is a crappy 5" columbian vise...
        I put in a little bit too much heat, and there was a little zinc still on the bolt but here is one of the 4 adjustable footpads 1" diameter grade 8 bolt and a 1/4" plate
          I GOT THE SAME TABLE AND I USED 3X3X1/4 TUBING ALSO 4X4X1/2 ANGLE WORKS GREAT
            not everyone has this luxery but at work our welding table is made out of 1 inch thick 4 inch wide square tubing for the base and the top is a old die base that is 8 inches thick and 12 feet long and 5 feet wide heavy duty
              how large is the foot plate ??
              i have a 5'X3-1/2'X1-1/8" (some thing like that) and i used a solid pice between the 2 legs on each end. not the best option for leveling but my floor needed the help.
              thanks for the help
                They are just under 4" I think 3 7/8..
                I ended up cutting up another I beam, and used that for the legs because Im out of square scraps.
                  Don't know where you're located but if you have access to it get some used 2 7/8 tubing from the oilfield. make the legs like h-braces. very stout and also doubles as you can lay tubing on the supports under the table for easy access. Hope this helps
                  At Home
                  Miller Thunderbolt XL AC/DC
                  Performance Tools 6" Bench Grinder
                  Craftsman Hand Tools
                  Craftsman Cordless Drills
                  DeWalt Angle Grinder
                  1976 AMC Jeep CJ7
                  1980 Ford F150 Custom
                  1994 Chevrolet Silverado C1500
                  At Work
                  Miller Bobcat 250
                  2 Miller MM251s
                  2 Miller MM252s
                  Miller Dialarc 250 AC/DC
                  Lincoln Idealarc 250 AC/DC
                  Snap-On Flux Core Welding Machine
                  Hypertherm Plasma Cutter
                  Victor Torches
                  2006 Chevrolet Silverado 2500HD 4x4
                  Proud American Ham KE5TJA
