I weld these SS cam brakes at my work every few weeks and they always seem to warp, it doesn't affect the way the brakes work but I would like to weld them and have them stay true. The plate is 3/8 308 SS and the pipe is 4" sch 40 TIG(whoops I mean GTAW, just joking) welded all the way around. I usually weld a 1 1/2 fillet on one side then a 1 1/2 lap on the other side, then let it cool down and continue. The pipe is 5 1/2" long but by the time they are finished the gap between the ends of the plates is 5 1/8". I've tried putting a 5 1/2" piece of metal between the ends and welding it but when it's finished and cooled I have to smash it out from between the plates and it's still warped. Any help is appreciated.
warpage on 3/8 SS
Tags: None
here's some pics of the brakes, sorry for the quality.Welders do it hotter!!
www.Munsonworks.com
2 suggestions...
Clamp the flat section down hard with something behind it
to bend it a little against the way it's warping.
Mig it instead of tig if you can, the mig is a lot faster
and you will put less TOTAL heat into the assm that way.
I usually have much better luck with respect to warpage
running a mig" hot and fast" vs. poking along with the tig.
Dave P.
if possible try what fm117 is saying.two other options (but they are after its been welded)is applying heat on the opposite side to pull it back out.the other is using a small hydraulic jack to straighten.2- XMT's 350 cc/cv
1- Blue star 185
1- BOBCAT 250
1- TRAILBLAZER 302
1- MILLER DVI
2- PASSPORT PLUS
1- DYNASTY 200 DX
1- DYNASTY 280 DX
1- MAXSTAR 150 STL
1- HF-251 BOX
1- S-74D
1- S-75DXA
2- 12-RC SUITCASES
1- 8-VS SUITCASE
2- 30 A SPOOLGUNS
