Welding a vehicle frame
  • Welding a vehicle frame
    Can anyone offer me some tips on welding a vehicle frame together? What I would like to do is cut a vehicle frame in half(because the rear frame is bent) and weld a good rear half back on to it. The truck frame would need to be cut in the center, so there would be a lot of stress in this area. Please be aware this frame is a box type frame.
    My plan is to make a top to bottom vertical cut and then weld it back together like a butt joint. What could I do to make this area as strong as it needs to be.
    Thanks
    It would need more reinforcement than just butt welding it back together.
    You will need some sort of fish plates welded over the butt joints, and perhaps more reincorcement.
    You also might consider making a step cut in each of the frames, and having them mate together.
    Finally, this might be a bad idea altogether, and it might be better to just find a straight frame, if possible.
    -James
      No straight cuts on frames. Sides, and top/bottom flanges should be cut on 45 degree angles to disperse stress loads and to allow for greatest amount of weld surface area.
      To re-inforce, either load frame inside with tubing that fits inside of current frame, or weld on "fish plating" or load dispersing panels on the outside as mentioned.
      Maybe do some checking around to see if someone in your area has done this sort of thing before and is willing to give you some tips and hands-on demonstration.
      I have no idea of your skill level, and intend no insult, but when doing this kind of work, you don't really have any room for errors.
      Opinions vary, this is how I'd do it.
      Best of Luck.
      Later,
      Jason
        Don't hold me to the wall here but I read somewhere not to do vertical welds on a frame especially in an area of high stress. If you did weld the new back half
        of the frame on you would need reinforcement plates. Again, when welding the side plates, weld only the horzintal top and bottom, not the vertical left and right ends.............per the article I read. The heat generated at the vertical welds changes the metal some and invites a new place to break.
        Be sure to get the advice of a pro.
        Nick
        Miller 252 Mig
        Miller Cricket XL
        Millermatic 150 Mig
        Miller Syncrowave 200 Tig
        2-O/A outfits
        Jet Lathe and Mill
        Jet 7x12 horz/vert band saw
        DeWalt Multi Cutter metal saw
        Century 50 Amp Plasma Cutter
        Propane Forge
        60" X 60" router/plasma table
          Ditto
          Vertical welds will ALWAYS break because the stress is pulling across the the width of the bead instead of dispersing along the length.
          Good luck.
          Triggerman
          Ammonia refrigeration tech
          Millermatic 180 w/Autoset
          CST-250
          HF-15 High frequency
          XR15 w/Push-Pull Gun
            Interesting. Would seem odd (to this newbie type) to leave ends of fish plate bare. Could you put a couple of plug welds near each edge, iinstead?
            And, someone above had suggested a step cut. Are you saying the verticals there can't be welded?
              Atrorm
              No vertical welds. They ALWAYS crack.
              Triggerman
              CST-250
                Good luck.
                Ahhh yes, tension vs. shear
                For Aircraft we use a 30 degree angle for all splices, along with a doubler inside, or a sleeve outside of the tube, also with the ends cut at 30 degrees if an external sleeve. Is this for on or off road use? Depending on the State, the local DOT may have regulations on this type of repair.
                -Aaron
                Miller Dynasty 300DX
                Miller Dynasty 200DX
                Miller Spectrum 375 extreme
                Miller Millermatic Passport
                Miller Spot Welder
                Motor-Guard stud welder
                  Before you even attempt this, you may also want to check with an inspection station. This may not even be legal and the liability could also be a problem if you or somebody else would be involved in an accident.
                  Another tip, when a vehicle is made, the VIN number is stamped at least 10 different places on a vehicle so it or its parts can be traced when they are stolen. You may even need to apply for a reconstructed title.
                  Ken
                  What else is there besides welding and riding. Besides that
                  Miller Thunderbolt XL 300/200 AC/DC
                  Hobart Handler 187
                  Dewalt Chop Saw
                  4" Air Grinder
                  Die Grinder
                  Rigid Drill Press
                  Kellogg 10hp Air Compressor
                  2009 FXDC
                    welded frame
                    i did a mack truck one time..the owner said he went to mac truck and asked them ..this is what he had me do...cut on 30 degree angle..weld all around and then grind the outside flush..he had ordered another C channel from Mack to fit over the original frame...stuck by `18 inches each side...six bolts on each side...no welding on this piece allowed..
                    the top flange of the channel was allowed to be notched for any obstructions caused by the original frame but not the bottom flange...anything here had to be removed and put back on the new bottom flange
                      sleeve it
                      Wirefeeder, assuming you are sectioning this frame in a more or less straight and flat area.....I would cut it at approximately 30 deg and install a sleeve at least the same thickness material . The length would be twice the height of the frame rail involved as long as you have clearance to fit . Rosette weld/spot weld minimum four spots per side of each rail plus leave about 1/8 gap between rails with a bevel on rails to make full penetration with sleeve when fully welded together. This method has been done in our shop successfully. Also if its a late model vehicle you might have to check with your DOT about VIN numbers etc. If its an older vehicle Weld On
                      Hope this helps Jim [email protected]
                      Welding in Crete
                      Syncrowave 350 LX
                      Millermatic 252
                      Millermatic 180 w Spoolgun
                      Miller Gold Seal 155
                      Miller Elite welding helmet
                      JD2 Tubing bender with Hydraulic conversion
                      Evolution Raptor15" SteelDry Cut Saw
                      Hypertherm Powermax 30
                      Some really cool hammers BIG and small
                        [QUOTE=billie-t;23739]i did a mack truck one time..the owner said he went to mac truck and asked them ..this is what he had me do...cut on 30 degree angle..weld all around and then grind the outside flush..he had ordered another C channel from Mack to fit over the original frame...stuck by `18 inches each side...six bolts on each side...no welding on this piece allowed..
                        the top flange of the channel was allowed to be notched for any obstructions caused by the original frame but not the bottom flange...anything here had to be removed and put back on the new bottom flange[/Q
                        billie-t, you are right on target with your reply.
                        This is the method that we have followed as instructed by several vehicle manufacturers. The bolts should also be a minimum of 5/8" diameter with a shank where it goes through the frame and grade 8 also. Dave
                          [QUOTE=dabar39;24176]
                          The only problem with that repair is it cant be done on a box frame..its a C channel frame repair.......but it is the way to go on a semi or other heavy duty truck
                          Jim
                          Welding in Crete
                          Syncrowave 350 LX
                          Millermatic 252
