I bought some 5/32 super abrasive electrodes to add some hardener to one of our cast iron plow shoes to try it out before we do the whole fleet. These rods have roughly 1/4 inch of flux on them, I may be exaggerating a little but it is very thick. I never used these rods before and on the box it says to set the amps at 140 - 160 which sounds right. My question is, with that much flux, how can you tell how much of a bead you are laying or is best to run a practice bead ?
Super Abrasive Welding
I would just run a short practice bead to get a feel for the rod and the setting, better than testing on a good workpiece. This is what I do whenever I use a new type or size of rod.Dynasty 200DX, first generationMakita 5" grinder
Makita 14" abrasive sawIR SS5L compressorWhole bunch of hand/air tools.and a wish list a mile long
hard surface rods run similar to 7018. Make sure you have a very clean surface to weld those high dollar rods to. I usually run a pass of 7018 before I start hardsurfacing. Seems to leave less pitting.68 Lincoln SA200
Miller pro 300
64 Lincoln SAF 300
Lincoln 305G
MillerMatic 210
More tools than a showdog can jump over
Thanks guys, I ran a practice bead today without preheating to give it a try. Ran a bead across a junk brake caliper at 170A so I think with a little preheating, it should be pretty simple.Ken
What else is there besides welding and riding. Besides that
Miller Thunderbolt XL 300/200 AC/DC
Hobart Handler 187
Dewalt Chop Saw
4" Air Grinder
Die Grinder
Rigid Drill Press
Kellogg 10hp Air Compressor
2009 FXDC
Originally posted by robphillips View Posthard surface rods run similar to 7018. Make sure you have a very clean surface to weld those high dollar rods to. I usually run a pass of 7018 before I start hardsurfacing. Seems to leave less pitting.Jim
