Which tig Dynasty 200 DX or 350
  • Which tig Dynasty 200 DX or 350
    I want to start learning to tig weld at home just for a hobby. I currently use a Lincoln SP-135 mig and an old Lincoln Weldan Power AC-150 stick. My main use would be mild steel and aluminum under 1/4 inch thickness. I also would like it to be portable. I've read through the spec sheets on both machines. I'm just not sure if it would be a smart move going for the more expensive machine with all the different settings or to start out with a more basic machine then work up to the high end machine.
    Thank you for your assistance.
    A Dynasty 200dx is a high end machine.
    A basic tig would be a Miller Syncrowave 200.
    If all you're going to do is 1/4" steel and aluminum at home then go with the Dynasty 200dx.
    -James
