Is there an easy way to determine if I have a piece of cast steel or if it is cast iron?
Cast iron/cast steel
If it will cut with a torch it is cast steel, cast iron will only meltLincoln: Eagle 10,000, Weld-Pak HD, Weld-Pak 155, AC-225, LN-25 wirefeeder
Miller: Syncrowave 250DX Tigrunner
Westinghouse: 400+ amp AC
ThermalArc Handy wirefeeder
1 Harris, 3 Victor O/A rigs
Arcair gouger
Usually cast iron has a rough finish to it such as a cast iron frying pan or weights in a gym, engine blocks, looking close enough, you can see or feel the pores from the sand casting.
Cast steel has a smooth finish to it like some cookware, motor housings, gears, sprockets, etc.Ken
What else is there besides welding and riding. Besides that
Miller Thunderbolt XL 300/200 AC/DC
Hobart Handler 187
Dewalt Chop Saw
4" Air Grinder
Die Grinder
Rigid Drill Press
Kellogg 10hp Air Compressor
2009 FXDC
Toe test! drop it on your toe, cast steel makes you say OOUUChh !,cast iron makes you [email protected]#%%#^%#
Seriously though, spark test. Dull orange sparks off a grinding wheel are iron, steel is yellow.
