wood cutting VS metal cutting band saws
  • wood cutting VS metal cutting band saws
    I'm slowly getting equiped in metal working. I have a fairly heavy duty floor model 14' band saw. Is it possible to convert this to metal cutting if a metal cutting blade the right lenght can be found ?
    You'll not only have to change the blade, the speed will have to be reduced as well.
      What are you looking to cut on it?
      Miller Maxstar 200 DX
      RMLS-14 Momentary Hand Control
      Miller Syncrowave 180 SD
      Porter Cable 14" dry metal saw
      Hitachi 4.5" grinder
      http://mhayesdesign.com
        I probably wont be welding anything thicker than 1/4 inch or so as I only own a mm180. This will only be for my workshop where I plan to do light fabrication only. I was lookinh at getting a dry cutting chop saw or an inexpensive horizontal band saw but thought I could make use of my floor model bandsaw in the meantime.
          A vertical bandsaw is good for cutting 16 ga. sheet (and it's not even really good for that). I would reccomend an abrasive saw or horiz bandsaw. Dry saw or cold saw if you're rich.
            I converted a Powermatic vertical band saw from wood to steel, and it works great. I used a variable speed DC gearmotor from a belt conveyor to slow it down.
              Speed is most of it. Most wood saw are not built to handle the stresses of metal cutting puts on it.
              I have a wood saw and I cut sheet steel with it, but it is hard on it non the less.
              Also to cut bar type stock an abrasive type saw works, and a cold saw is cool, you don't have to be "rich" to own one. Just keep your eyes open for a bargain.
                The horizontal bandsaws are really the way to go, since the blades are so cheap.
                The dry saws are nice for $600, but the blades run out fast. Cold saws last last a long time. Grizzly sells one for ~$1000. Grizzly has a horizontal bandsaw that cuts up to 60 degrees for about $1500. Replacement blades are $20-40.
                  I aquired an 18" Jet wood saw recently, in reseaching a conversion I found this on practicalmachinist.com, for future reference. Hopes this helps
                  Good luck
                  L*S
                  I have a woodworking bandsaw that I would like to modify to enable metal cutting. I plan to change the motor to 3ph and use a variable speed drive to get the cutting speed down for steel. Has anyone done this? I would appreciate any comments/advice about the merits of my idea. If I had more...
                    Thanks Leons2003,
                    Great advice in that forum. Sounds like alot of work to properly do a conversion like some of them describe but it answers all of my questions.
                      JC,
                      Since you have a nice wood shop I wouldn't want to use one bandsaw as once you start cuttin' metal the chips will be in the saw fahevah, and also the Lubricant that goes along with cuttin' metal
                      Ed Conley
                      MM252
                      MM211
                      Passport Plus w/Spool Gun
                      TA185
                      Miller 125c Plasma 120v
                      O/A set
                      SO 2020 Bender
                      You can call me Bacchus
                        Originally posted by Broccoli1 View Post
                        JC,
                        Yeah, I would get a dedicated metal saw if you're serious about fabrication. I don't like using verticle bandsaws for metal anyway; just not enough control.
                          I only work with aluminum and have a plain old Delta 14" that I bought at Lowes.
                          I simply put a metal blade on it and it cuts aluminum like butter...the faster speed is great! It has really bean a huge change in the way I make things out of sheet aluminum like diamond plate and such. I love it!
                          But for steel it is pure junk For that I use my trusty chi-com 4x6" and a Milwaukie chop saw.
                          Miller 30-A Spoolgun
                          Miller WC-115-A
                          Miller Spectrum 300
