I'm slowly getting equiped in metal working. I have a fairly heavy duty floor model 14' band saw. Is it possible to convert this to metal cutting if a metal cutting blade the right lenght can be found ?
wood cutting VS metal cutting band saws
What are you looking to cut on it?Miller Maxstar 200 DX
Miller Syncrowave 180 SD
Hitachi 4.5" grinder
http://mhayesdesign.com
I probably wont be welding anything thicker than 1/4 inch or so as I only own a mm180. This will only be for my workshop where I plan to do light fabrication only. I was lookinh at getting a dry cutting chop saw or an inexpensive horizontal band saw but thought I could make use of my floor model bandsaw in the meantime.
A vertical bandsaw is good for cutting 16 ga. sheet (and it's not even really good for that). I would reccomend an abrasive saw or horiz bandsaw. Dry saw or cold saw if you're rich.Miller Maxstar 200 DX
Speed is most of it. Most wood saw are not built to handle the stresses of metal cutting puts on it.
I have a wood saw and I cut sheet steel with it, but it is hard on it non the less.
Also to cut bar type stock an abrasive type saw works, and a cold saw is cool, you don't have to be "rich" to own one. Just keep your eyes open for a bargain.
The horizontal bandsaws are really the way to go, since the blades are so cheap.
The dry saws are nice for $600, but the blades run out fast. Cold saws last last a long time. Grizzly sells one for ~$1000. Grizzly has a horizontal bandsaw that cuts up to 60 degrees for about $1500. Replacement blades are $20-40.Miller Maxstar 200 DX
I aquired an 18" Jet wood saw recently, in reseaching a conversion I found this on practicalmachinist.com, for future reference. Hopes this helps
Good luck
L*S
http://www.practicalmachinist.com/vb...rsion+to+metal
JC,
Since you have a nice wood shop I wouldn't want to use one bandsaw as once you start cuttin' metal the chips will be in the saw fahevah, and also the Lubricant that goes along with cuttin' metalEd Conley
MM252
MM211
Passport Plus w/Spool Gun
TA185
Miller 125c Plasma 120v
O/A set
SO 2020 Bender
You can call me Bacchus
Originally posted by Broccoli1 View PostJC,
Since you have a nice wood shop I wouldn't want to use one bandsaw as once you start cuttin' metal the chips will be in the saw fahevah, and also the Lubricant that goes along with cuttin' metalMiller Maxstar 200 DX
I only work with aluminum and have a plain old Delta 14" that I bought at Lowes.
I simply put a metal blade on it and it cuts aluminum like butter...the faster speed is great!It has really bean a huge change in the way I make things out of sheet aluminum like diamond plate and such. I love it!
But for steel it is pure junkFor that I use my trusty chi-com 4x6" and a Milwaukie chop saw.
Miller 30-A Spoolgun
Miller WC-115-A
Miller Spectrum 300
