Originally posted by AnotherDano
View Post
Wiring Angst
Romex in conduit
I'm still following this thread, as an interested amateur.
I thought there are two potential problems with running NM in conduit. One being excessive heat buildup. Secondly, running this configuration underground, in which case the cable would still have to be underground rated, due to moisture issues, and breakdown of jacket and paper liner.
Originally posted by angus99 View Postthanks! It was a great experience for both of us.
Nothing illegal, I hope, with running romex in conduit?
Next time, run individual wires and you'll see.
Originally posted by tnjind View PostI think what Walker meant was, 10-2 is a "Romex" type wire. Meaning it is all combined in a singulaur type piece that is normal ran thrugh walls.
It is cheaper to run individual 10 gauge wires, especially through conduit.
I am glad everything worked out. Yuo got some good time with you son also.
BTW, you can't run 10-2wire (it is covered in insulation) in a conduit. You would need to THHN (idividual wires).
Originally posted by MMW View PostIf this is a rental unit then I would be very careful about checking into the laws/codes in doing this. I know in some areas it is illegal to do electrical work on a rental property without being licensed even if you have permission from the owner or if you own the property yourself. If you do the work then you are liable for any problems down the road. Having said that, I also know things like this are done all the time & if done correctly will never have a problem.
Is the 4-wire outlet far away from his work area? I'm guessng you were saying it's about 100'. Otherwise you could just create an adapter cable to go from the 3-wire to 4-wire.
The calculators I've seen let you go up to 140 feet with 10-2, and our longest run turned out to be around 130 feet. Also, he'll almost never use the welder at full capacity.
In any event, my son & I worked about 10 hours yesterday and ran a total of about 140 feet of emt and 10-2 wire to power two new 240-v receptacles for his welder. It was tough going--working on a scissors lift on 18-foot ceilings--but a great project for us to work together on. Tested across all the hot legs/grounds at the two receptacles we installed and the 1 previously existing receptacle and all are right a 124 volts per leg. (I did not test across both hot wires since I wasn't sure I could do that and didn't have internet service so I could check here for advice on. Learned this morning that doing so should yield 220 to 240 volts.) So we finished up about 10 p.m., powered up the welder for a minute and then shut off the breaker until the electrician can double check our work.
Thank very much to everyone for the expert advice. I really appreciate the help.
Happy New Year.
angus
If my memory serves me, a run of 160 feet that would handle 20+ amps would require 6AWG wire. And it would be improper to add the larger size wire onto a circuit that is already lesser in size.
I don't know if your son will be using the welder to full capacity, but for code/saftey reasons, you may want to install proper sized wire from the braker out.
I'll try and find my charts, and copy some more info for you in a little bit.
No Worrys
Thats what these forums are here for,one helping others,,As dano said,you would be a hero in your land lords eyes,as the price of copper,and your helping him out also,and it would be the quickest,Hanging the conduit takes time,and a pain,again as Dano said,no sub panels,seem kind of srtange???But were not there!
I would do your option 1 cheapest,easyiest,,,My 2 cents!
I would ask the land lord,if when he bought the building,did they Unwire a 220 wall recpt???????????Just a thought!!
I don't see a problem with that. If you like your landlord, you could run all four wires through the conduit and just use three, leaving him the option of having the neurtal for some later purpose. The difference would be the cost of another wire and the additional labor to pull it. It's much cheaper on the labor to do it now. The neutral wire would just be capped off at the studio outlet, but wired through the 'buffer' outlet.
Otherwise, pull a black, red and ground through the conduit and make your connections, ignoring the neutral at the 'buffer' outlet.
Curious... In that 'buffer' outlet, what color wires are present?
storts, it's definitely empty conduit running only part way out of the studio. But I can definitely use that conduit for the new circuit.
I had another thought, if anyone's not already burned out on this. Sorry to have so many questions, but I don't want to overlook the best solution.
If I wanted to keep that existing, seldom-used 120/240 circuit live and untouched (it's for a floor polisher), could I do this?- Leave the 4-wire circuit running from the breaker panel to its receptacle as-is.
- Just tap the two hots and ground on the 4-wire at the junction box and run 2 hots and a ground from the junction box on to the studio
In this scenario, the neutral on the 4-wire would be untouched--still connected at the panel and receptacle--but would not be part of the 3-wire circuit.
The owner of the building would prefer to have continued access to that original 4-wire circuit, if possible, but might actually use it once or twice a year and NEVER while my son is using his welder.
This would be by far the easiest and cheapest if it's safe and up to code.
Thank very much.
angus
2 questions
As an interested amateur, I'm wondering 2 things.
1) Why is there no sub-panel in the studio?
2) Is a run of 160 feet so long that larger wire is needed to offset current loss?
