Bushings for Pipe Roller Jack Stand
  • Bushings for Pipe Roller Jack Stand
    I'm in the process of making a couple of pipe jack stands. Instead of the standard "V" heads, these are going to have two 1/2" x 4" disc type rollers. I've turned them on the lathe already but want to press in bronze bushings instead of just driling a hole in the steel disc.
    My question is this: What size should I drill/ream/bore the hole in the disc roller? The bronze bearings I've purchased are 3/4" OD and 1/2" ID. I've already drilled 1/2" holes in the frame for the pins and the bushings slide over them quite nice. However, I need to press in the bushings so they are tight in the disc rollers and don't spin. I've measured the bushings and they are pretty much spot on (0.7500 OD and 0.500 ID). I'm guessing I need to bore the holes slightly under and press in the bushing, but I'm not sure by how much. I guess I could bore a few test holes and figure it out, but thought you guys might help me get it right the first time.
    Thanks
    Millermatic 35
    Miller TB302G
    Ellis 1800
    Smith & Victor Torches
    Optrel Satellite
    Arcair K4000
    Ingersoll-Rand 175CFM Diesel Air Compressor
    Home Made Welding Trailer
    Most of the time when I'm going for a decent cold press fit, I bore the holes .003" undersize and put a slight lead on the bushings with a file.
      Taking a closer look at the bushings, they are 0.005 over. I can purchase a reamer that is 0.7490. Perhaps that would be an option instead of setting up and dialing in my boring bar. Would that be too tight or should I go with the 0.7500 reamer?
      Millermatic 35
      Miller TB302G
      Ellis 1800
      Optrel Satellite
      Arcair K4000
        If you goof up a bit Locktite them in.
          Red or blue? You know, I can always count on Sberry for the old shop tricks!
          I ordered a 0.7500 reamer because I'm too lazy to dig out my nice high dollar Kennamental boring bar and make multiple passes to dial it in. I had to order some more bushings and they are spec'ed at 0.0000 to -0.0005 or something like that. So, locktite may be required depending on how bad my lathe is vibrating that day.
          Millermatic 35
          Miller TB302G
          Ellis 1800
          Optrel Satellite
          Arcair K4000
            It's looks like you have a hub. Why not drill a hole and use a roll pin. Very easy.
            Nick
            Miller 252 Mig
            Miller Cricket XL
            Millermatic 150 Mig
            Miller Syncrowave 200 Tig
            2-O/A outfits
            Jet Lathe and Mill
            Jet 7x12 horz/vert band saw
            DeWalt Multi Cutter metal saw
            Century 50 Amp Plasma Cutter
            Propane Forge
            60" X 60" router/plasma table
              That's what I have up to this point. I started with a 1.25" thick piece of 4" flat bar, cut them into 4" squares, trimmed off the edges, drilled them with a 1/2" center hole and turned them on the lathe. I turned a 1/4" x 1" hub on each end and faced down the roller to 1/2" thick. But, I'd like to be able to replace the bronze bushings if they ever wear out in my lifetime. Realistically, the rollers will probably be trashed by then, but where's the fun in that?
              Millermatic 35
              Miller TB302G
              Ellis 1800
              Optrel Satellite
              Arcair K4000
                I suspect you would never wear out the bolts you have now, would take rotating pipe 24 hrs a day at higher speed than a man can do it. Little portable ones I can lay on my benches.
                  That's a cool idea. I need to find a set of steel caster wheels and save myself the hassle.
                  I know if I were to use bearings, I couldn't pass welding current through them (ground clamp placed on the jack stand), but I'm hoping the bushings will work for this. If not, no big deal.
                  Millermatic 35
                  Miller TB302G
                  Ellis 1800
                  Optrel Satellite
                  Arcair K4000
                    I like the fact that you have them in your dining room!
                    Homemade Water Cooler
                    130XP MIG
                    Spectrum 375
                    60 year old Logan Lathe
                    Select Machine and Tool Mill
                      Yeah, the things I drag in and put on her dinning table really thrills the wife.
                      Millermatic 35
                      Miller TB302G
                      Ellis 1800
                      Optrel Satellite
                      Arcair K4000
                        You don't know Gary. That's his break area in the shop. LOL
                        life is good
                          Hey Harv, good to see you around. Just finished the welding portion of a corral with 18 gates. Oh, and one slider gate. Man, that was a lot of welding. Kind of reminds me of some of your bigger customer projects. Hope all is well.
                          Millermatic 35
                          Miller TB302G
                          Ellis 1800
                          Optrel Satellite
                          Arcair K4000
                            It's all good Gary.
                            I've been watching this because I'm building a machine to bale plastic trash into bricks for housing projects in the third world. I've ordered some one inch 4 tpi acme thread rod for the push mechanism. I'll need a bushing or three.
                            life is good
                              Sounds like a cool project and I'm sure you are up to it. Post some pics as it comes along.
                              Millermatic 35
                              Miller TB302G
                              Ellis 1800
                              Optrel Satellite
                              Arcair K4000
