We just got a 22A wire feeder at my work and I am having some problems getting the voltage read-out to work. The manual says connent the volt sense lead to the work, which I did, but I still get no read out. If I switch between wire speed and voltage really quickly while not welding I get random readings for a split second( 54.9, 3, 11.5, random numbers). Has anyone else had this happen or know how to properly use the volt sense lead?
Volt sense lead on 22A wire feeder
Tags: None
Clavacle, I have a four year old S-22A wire feeder with voltage sensing connected to an XMT 350 CC/CV power source. My S-22A's voltage sensor is working fine, but it sounds like yours needs repair. If you need it fixed, I suggest that you contact a Miller authorized repair shop.
As I understand the voltage sensing feature, it is intended as a voltage double-check where continuity may be a problem or for use where the power source has no voltage readout of its own. I have found that with the small to medium projects I've done, the S-22A's voltage readout is identical to the XMT's. I try to keep the ground clamp connection clean and close to the weld. This is why I seldom use the S-22A's voltage wire clip anymore. I hope this helps.Miller XMT-350 CC/CV
Miller S-22A wirefeeder
Bernard 400A "Q" gun
Miller 30-A Spoolmatic w/WC-24
CK 210 & WP-18 GTAW torches
Hypertherm Powermax 30
O/A Rig, Enco 4x6 bandsaw, etc.
I got a wiring diagram from a Miller tech guy and there was a couple of wires and switches we had to change to get a voltage read-out. The voltage reading jumps around a little but I am just happy to not have to do my settings by large numbers, I can really dial them in. Awsome!!Welders do it hotter!!
www.Munsonworks.com
