Alternatives to welding aluminum for puppet stage?
  • Alternatives to welding aluminum for puppet stage?
    I just joined this forum because I was looking for alternatives to welding for a puppet stage project I have in mind. I didn't know where else to go.
    I know a shop where the weld aluminum tube on a regular basis. In my case, the heaviest material I will want to use is 1x1 x .060"square tubing (probably .030 wall if I can). But, they say that welding the thin-wall stuff is a problem because the process tends to blast away the base material.
    So, I am looking for alternatives to welding. Here are some options I am considering, but am unsure what will be the best choice;
    - Using flat "L" brackets or triangular gussets and riveting
    those to the frame.
    - Same as above, but epoxying to the frame.
    - Fiberglassing the joint.
    Any comments or other ideas?
    Joe Dunfee
    those to the frame.
    Joe Dunfee
    Riveting will work and should be pretty cost effective. There is also a transportation grade two part glue or epoxy that I use at work, it would be more than enough in this application. I don't know what the name of it is but I can let you know when I go back to work on Jan 2.
    at home:
    2008 Suitcase 12RC
    Spoolmatic 30A
    WC-24
    2009 Dynasty 200DX
    2000 XMT 304
    Sold:MM130XP
    Sold:MM 251
    Sold:CST 280
    at work:
    Invision 350MP
    Dynasty 350
    Millermatic 350P
      sticky situation...
      you could use adhesives.
      try searching out a company called LORD adhesives. they make glues and two parts for everything under the sun and they stick like $hit on a wool blanket.
      http://www.lordfulfillment.com/upload/SG1006.pdf
      http://www.lord.com/Home/ProductsSer...3/Default.aspx
      if you make some corner gussets and use some clamps you could glue your stage together and is would, im sure, hold up very well.
      I wouldnt suggest fiberglass though. its way messier than you want to know. and a pain in the a$$ to deal with.. it stinks, its sticky,frustrating, and expensive..
      as for "blowing out the base metal" that is indicative of skill level..
      A good TIG man shold be able to weld pop cans together on a regular basis...
      ASK ENGLOID on the motorsports side... he is very much experienced.
      Miller 251/30A spool
      Syncro200
      Spectrum 625
      O/A
      Precix 5x10 CNC Router12"Z
      Standard modern lathe
      horizontal 7x12 bandsaw
      Roland XC540 PRO III
      54" laminator
      little dog
        Thanks for the replies. I think I am going to go with epoxy.
        Joe Dunfee
          it seems strange to join a welding forum to find an alternative to welding. but you could use a low heat soder/weld material. try these guys
          http://www.aladdin3in1.com/
          like said above TIG would be a good choice but MIG may not work out so well on that thin. i would TIG weld it but you could try the stuff aladin has as another option, or go with a 2 part epoxy.
          good luck
          sigpic
            Try JB Weld
            http://jbweld.net/products/index.php
