did you know?
  • did you know?
    you can weld alum to steel. anyone know the process???
    just a brain teaser
    Cold Metal Transfer ?
    Neo
    Best Regard,
    __________________
    Jesse
    aka Neo
    Miller Passport
    Miller 225G
    Red 255
    VIctor O/A
    Wish list:
    Maxstar 150STH or
    Syncrowave 250DX
    A Dynasty 300 if I am wishing really hard..
      Well????
      A lot has been tried but nothing yet as far as I have heard passes NDT, DT, Dye and X-ray. Cold transfer is used for non critical apps, but controled explosive bonding is the only process I know that is used for critical apps and is of a proprietary process and from what I have heard is very very expensive.
      My guess??
      TacMig
      We depend On:
      Miller | Esab | Lincoln | Fronius
      Baileigh | Drake | Eagle | Knuth
      Victor | Harris | Smith | Bessey
      Snap-On | Hilti | Ingersoll Rand
      Burco/Koco | Onan | BobCat
      Tracker | Infratrol | AmeriCast
      We belong to or support:
      American National Standards Institute
      American Welding Society
      The Welding Institute
      Fabricators & Manufacturing Association Int'l.
      Anderson & Co. LLC
      Metal Cr
      afters
        nope unfamiliar with this process. can you explain??
        thanks
          thanks
          Cold transfer or Explosive..??
          TacMig
          We depend On:
          Anderson & Co. LLC
          Metal Cr
          afters
            From what I can compile process involves "tinning" the material with bronze. then followed with silver but i can"t seem to find anything else on it.
            My guess is that the application is soley ment for decorative purposes, but would appreciate any other info
              Cold transfer? Explosive?
                I would too..
                This process is way out of my ball park and have only read about it will passing the time in the growler I'm not even going to take a shot at it. I will try to find the mag and send you the info if I can find it, I do know or perhaps better said, I think explosive bonding is a process of shape charging the Al to the steel in a controled enviroment??
                TacMig
                We depend On:
                Anderson & Co. LLC
                Metal Cr
                afters
                  The shop I used to work at (temp. layoff) had a trailer division. One of the guys I worked with showed me a piece of Aluminum somehow bonded to Steel that acted as a sort of weld in adapter. I'm not really sure how they were joined, but you could clearly see the line of speration between the two metals. I'm going to go out on a limb and say theat the strength of this join was very high as it is used on load bearing transport trailers on public roads.
                  Owner of Burnt Beard Fabrication & Welding Ltd.
                  BigBlue 500D
                  Millermatic 211
                  4' Box and Pan Break
                  IR compressor
                    tacmig
                    thanks for the input
                    i'd appreciate it if you do happen to come across anything. if i do i'll let you know.
                    thanks again
                      Its called cladding like the nickle and copper in coins. It is done underground outside Pittsburg with explosives. The force of the blast seals the different metals together....Bob
                        I know what your talking about, I was also shown this on a drop deck trailer, didn't believe it until I saw it! I also was shown a coupon of 18ga cold rolled welded to a similar thickness aluminum coupon using a Fronius machine. It's cool to see constant devolopment in this great trade!
                        at home:
                        2008 Suitcase 12RC
                        Spoolmatic 30A
                        WC-24
                        2009 Dynasty 200DX
                        2000 XMT 304
                        Sold:MM130XP
                        Sold:MM 251
                        Sold:CST 280
                        at work:
                        Invision 350MP
                        Dynasty 350
                        Millermatic 350P
                          wow, thanks guy's, does anyone have any sort of references to this stuff???
                          I'd really appreciate it
                            Try this out..
                            I think you might get some more info from here.
                            Good luck,
                            TacMig
                            We depend On:
                            Anderson & Co. LLC
                            Metal Cr
                            afters
                              A few months ago while I was healing from surgery I watched a show about this process( Explosion } welding on the discovery channel, you may be able to contact them and buy the episode and as I remember the process was very successful.
                              Hope this helps
                              Wheelchair
