Also on the Hobart Projects Forum:
I did this job about 6 years ago, when all I had was a borrowed MM130 and .035 FCAW. But I finally got a digital picture of it in my E-mail from visiting the customer recently, and thought you guys might like to see it.
The arches are 3/4" square tubing, bent around a plywood circle that I made for the purpose. Then, 3/4 x 1/8" flat bar ties it all together and makes the frames for the two different sizes of castings. The aluminum castings were trimmed to shape when needed by a 4-1/2" grinder with 1/8" wheel.
The base of each leg has two bolts into concrete anchors and the high side is also screwed to a wall stud. The seam when the legs of the arches meet is also covered with 3/4" flat.
Finish was Rust-Oleum primer followed by Rust-Oleum Metallic Gold, all by rattlecan.
