I would like to buy a tubing bender for the shop I work at but Im not sure wich way to go. the majority of the work I will be doing will be with 1" to 2" tube but it would be nice to be able to use it for smaller stuff as well. I have looked at the hossfeld but it would end up being out of my price range with all of the dies for it. I dont want to spend anymore that about $1000 for the whole setup.
tube benders
Take a look at these. I have a hydraulic model 4 but if you don't mind bending manually for awhile you could get the model 3 and some dies for less than $1000.00 and add hydraulics later if you wish.
The Model 3 Tube Bender by JD Squared. This machine can bend from 1/2 inch to 2 inch OD tubing manually with little effort because of the compound leverage from the ratcheting arm and can be upgraded to hydraulic at any time. (For manual operation the Model 3 must be solidly attached to a fixture such as our Floor Pedestal). The Model 3 bender is CNC machined from high strength cold rolled steel. The die sets are equipped with replaceable alloy blocks. Die sets sold separately.MM251
Hypertherm45XP
protools makes a good one. So does JD2. The model 3 as show in the post above is good. The manuel benders are about the same style so it is just a brand preference. I got the protools one because it was made out of thicker metal.(1/2" insteaed of 3/8").
bender
Originally posted by ace4059 View Postprotools makes a good one. So does JD2. The model 3 as show in the post above is good. The manuel benders are about the same style so it is just a brand preference. I got the protools one because it was made out of thicker metal.(1/2" insteaed of 3/8").
I bought the American Bender version of the #2 Hossfeld (direct copy). The guy is good to deal with. I think the basic bender is about $800 and comes with tooling to do flat bar and solid square/round. I bought 1" square and round dies for about $200ish each. I am sure the web page is WWW.americanbender.com, or somthing close to that, google if its not. High quality, good support.
A
Originally posted by c neck View Posti was looking at shop outfitters anyone have one of these
Won't do 2" though
1-1/4" Max. but it does have accessories for Scroll work, Picket Twisting and baskets for Pickets.
Gonna set ya back about a 1,000.00 for the Bender and a couple of dies.Ed Conley
MM252
MM211
Passport Plus w/Spool Gun
TA185
Miller 125c Plasma 120v
O/A set
SO 2020 Bender
You can call me Bacchus
Originally posted by pollaccia View Posthow do you like this bender? I plan on buying one soon.
So on the thinner stuff .125" wall and less it work great. But on the thicker stuff you kinda struggle with it for a full 90 degree bend.
As far as protools vs. the [email protected]
The JD2 has a nicer handle but protools makes there out of thicker metal (the HD model)
