its the mil scale. trust me. grind it off so there is none closer than 1/2" to your weld. it should come out looking nicer and no black soot.
Tungsten help...
Originally posted by Canada View Postits the mil scale. trust me. grind it off so there is none closer than 1/2" to your weld. it should come out looking nicer and no black soot.
Theres your problem. Don't sand blast it. Blasting inbeds oxides and blasting media into the metal contaminating the welds. Since there arn't realy any scavenging agents alloyed into most Tig rods there can't be any contaminanints in the weld zone. We had the same problem at the last company I worked at. I kept telling them to stop blasting everything but they never listened. 45% of production time was spent making repairs.
Originally posted by Anti-GMAW View PostI kept telling them to stop blasting everything but they never listened. 45% of production time was spent making repairs.
Ken
What else is there besides welding and riding. Besides that
Miller Thunderbolt XL 300/200 AC/DC
Hobart Handler 187
Dewalt Chop Saw
4" Air Grinder
Die Grinder
Rigid Drill Press
Kellogg 10hp Air Compressor
2009 FXDC
Originally posted by Anti-GMAW View PostTheres your problem. Don't sand blast it. Blasting inbeds oxides and blasting media into the metal contaminating the welds. Since there arn't realy any scavenging agents alloyed into most Tig rods there can't be any contaminanints in the weld zone. We had the same problem at the last company I worked at. I kept telling them to stop blasting everything but they never listened. 45% of production time was spent making repairs.
tig probs
Trust me, your problem is nothing to do with contamination caused by sandblasting. Take it from technical training and years of experience. You've got the idea, just keep your tung out of the puddle and filler off of your electrode
Try not to freeze your puddle so quick. I notice that in some of the photos theres a small nib so to speak. This is the result of dipping your filler, but extinguishing the arc before the filler can completely puddle in.
Hope it helps
One more thing
HAVE PATIENCE
I think your touching the puddle too. when you do touch, the arc will make a crackly sound. iit wont hiss anymore for the time there is contact. its a nasty sound.. listen for it and then try to avoid it. And there may also be a flash of light as the arc is quenched and restruck. I spent the day building a stool to rest my big fat a$$. I touched the rod and the puddle alot. there was soot and smut everywhere... the end result turned out okay. Im sure my big fat a$$ wont mind a little charcoal..
and the suggestion to be patient, its a good one. Relax slow down, look around the puddle, study the arc, whats the steel doing? wheres the rod. how far above the work is the electrode. is the angel right? etc etc. if you take the time to look at these things you wil be able to jump start your learning curve three fold..
My machine just hit 11 hours of process... so far so good. I suck at stainless though...
In the pic i reposted (PC190019), Im pretty sure what ive said within the photo is correct, but if i am wrong I will stand corrected.Last edited by SignWave; 12-19-2007, 11:48 PM.Will it weld? I loooove electricity!
Miller 251/30A spool
Syncro200
Spectrum 625
O/A
Precix 5x10 CNC Router12"Z
Standard modern lathe
horizontal 7x12 bandsaw
Roland XC540 PRO III
54" laminator
little dog
thats strange i found stainless pretty smooth going. you do need good gas coverage and for a little longer than steel. i bump up the post flow a bit and go a little slower. thin stuff needs back gassing for shore or its.
other than that i thought it was about the nicest to weld.thanks for the help
[email protected]
Good to know! So the only way I should prep the surface is with acetone and a stainless wire brush? Or grinder?
if you don't already have them get some flap disks for your 4.5" grinder. they are fast and easy for cleaning up. work great after the weld also.
you might try upping the gas flow, or turning it down if it's too high it can cause turbulence and pull air into the weld. also make shore you don't have a draft coming across your work area. about 25 should be ok for gas if the air is still in the work area. i missed what you said it was set to, but i have gotten that black when i let my gas setting creep on me as my tank used up.thanks for the help
[email protected]
Thanks guys. The blasting media I use is glass bead also, so I can't really see that affecting the weld. I will keep trying and using different methods until I find what works for me; not trying to rush it
I'll post back with any progress! Thanks again.
this is the best $ i have found on a quality disk.
http://www.lehighvalleyabrasives.com/servlet/StoreFront
they are not walker's but for $2 each they are the best deal i have found.the quality is good also, its not cheepo crap like you would expect for the $. i was verry happy with the ones i got from them.
thanks for the help
[email protected]
nasty tig
I can see several problems..one is that you seem to be long arcing..also your travel speed is too high and the metal isn't prepped properly. Use that grinder. What rate was your argon set ? What size cup were you using ? How far was the tung sticking out ? Too much gas is as bad as too little gas. Thats also not a very good method for welding that size plate. Bevel the plate to a 37 1/2 degree angle, put a 1/8 inch landing on it and then separate the plates 1/8 inch and use 1/8 inch filler to run the root.
Anyone else have a better Idea?..I'd also invest in a gas lens and some gas cups number 4,6,8 maybe a 10 also.
