I wish to tig up the rear scope mount holes (missaligned) in a Mauser rifle action. I have been told this will not affect the rest of the actions heat treatment as its the rear holes I',m tiging. My question relates to the filler rod. Would a standard mild steel filler rod be ok or should i use something else (what?)
a question for the experts
can you post a pic? it may be advantageous.Will it weld? I loooove electricity!
Miller 251/30A spool
Syncro200
Spectrum 625
O/A
Precix 5x10 CNC Router12"Z
Standard modern lathe
horizontal 7x12 bandsaw
Roland XC540 PRO III
54" laminator
little dog
Originally posted by grahambr View PostI wish to tig up the rear scope mount holes (missaligned) in a Mauser rifle action. I have been told this will not affect the rest of the actions heat treatment as its the rear holes I',m tiging. My question relates to the filler rod. Would a standard mild steel filler rod be ok or should i use something else (what?)
Actions are commonly 4140 or 4130 steel and will anneal if you let them get too hot or warm for too long.
You will need ER80S-D2 tig rod. Make sure the hole is really clean prior to welding you do not want any porosity. Brake parts cleaner is good for degreasing. I would drill out any threads first also.
Good luck!!!Ron
ShopFloorTalk
Millermatic 350P, Roughneck 4012 and Ironmate guns
Dynasty 300DX, Coolmate 3, Crafter CS-310 Torch
Trailblazer 302, 12RC, WC-24
30A spoolgun
Spectrum 2050
Thermal Arc Plasma Welder PS-3000/WC-100B
Originally posted by Anti-GMAW View PostHow deep are the holes? I know a guy who tried to do the same thing on a mauser and blew right through. The holes were drilled to deep to begin with and he just asumed they were drilled to the proper depth.
Ron
ShopFloorTalk
30A spoolgun
Spectrum 2050
Originally posted by shadetreewelder View PostUmmmm.... I own Mausers, worked on Mausers and have been welding for 22 years if he blew through the receiver he was doing something WAY wrong...It's not the first time somone has drilled the holes to deep on a receiver. And yes you'r right, he did do somthing wrong. He should have checked the depth of the holes first instead of assuming they were ok. He set the machine up the same way he always did and found out the hard way that it wasn't right.
I can put you in touch with a guy in Douglas Wyoming, (USA) that used to build one of the original three position safety's for the Mauser 98 actions and probably one of the most knowledgeable regarding the heat treatment of the Mauser 98 actions..... not to mention a retired physicist to boot.
So you might ask how I know this chap???? Just so happens to be my father.Best Regard,
__________________
Jesse
aka Neo
Miller Passport
Miller 225G
Red 255
VIctor O/A
Wish list:
Maxstar 150STH or
Syncrowave 250DX
A Dynasty 300 if I am wishing really hard..
