There seems to be lots of BBQ projects on here, I was wondering if any one has built a sausage stuffer or have any ideas on how to biuld one. I was thinking about an air operated one with an air cylender. Does any one have any input as to if it would work.
Sausage stuffer
I've never seen a sausage stuffer. My recommendation would be to visit a meat processor and ask if they'd show you their sausage stuffing operation. You could see how it's done, what they're using and then go home and devise your own design to suit your needs. That's how I'd do it anyway.Blondie (Owner C & S Automotive)
Miller 340A/BP
Victor O/A torches
Lincoln SP125
Too many other tools to list
03 Ram 1500
78 GS1000
82 GL1100 Interstate
I have a good Idea on what I want to build. I guess I should have explained myself a bit better, sorry about that. What I was wondering is if it would work to use compressed air with a air cylender to drive the plunger to push the sausage meat out into the casings. I will be using a peice of 6" schedule 10, 316 stainless steel pipe 14" long. The plunger will be made of a peice of 1" thick HDPE plastic. It will be machined to fit inside the 6" and a groove will be machined into it so that I can install a rubber O ring. This is the peice that I want to drive with the compressed air. It will have to move fairly slow and I was unsure if it will move smoothly. Being that the air is compressible it would not have the same effect as something non compressible, ex: hudraulic fluid. It will have a three way valve and an air regulator for control.
Do you think this will work?
sausage stuffer
Stomper,
I have seen sausage stuffers in sporting goods catalogs.
Some use a ram and linkage like an oversized garlic press and others use a gear drive mechanism to provide the force.
I am no expert but I did a quick calculation of the area of your 6" IPS sch 10 pipe and compared it to theoretical 1", 1.5", 2" ID sausage.
6" IPS sch 10 pipe is 6.357" ID.
Area of pipe ID is 31.73 sq in.
1" sausage is .785 sq in
1.5" sausage is 1.76 sq in.
2" sausage is 3.14 sq in.
Comparing equivalent volumes,
1" of travel of your 6" IPS ram will give you:
40.4" of 1" sausage
17.9" of 1.5" sausage
10.1" of 2" sausage.
Get lots of casings!
This is simply a calculation based on volumes.
Greatly simplified, your stuffer is a large version of a caulking gun, but I have no idea of the pressures involved as this is most likely a topic for fluid mechanic experts.
I would consider how to streamline the flow path to minimize drag on the sausage mixture.
Maybe a cone shaped end for the ram and the cylinder like the toothpaste tube.
Good luck - please post photos as well as your recipe.Miller Dynasty 350, Dynasty 210 DX, Hypertherm 1000, Thermal Arc GTSW400, Airco Heliwelder II, oxy-fuel setup, metal cutting bandsaw, air compressor, drill press, etc.
Cool, thanks for the info. When you put it like that it will be alot of sausage. When I make sausage, deer, moose or elk, I usualy make a 5 gallon pail 3/4 full of the stuff. the biggest part of it, is stuffing it, so if this works it will take alot of the work out of it. The other idea that I had was to just make it a screw type operated stuffer, but thats not that cool. I want to p*mp it out a bit. Stream lining it would be a good idea. Thanks again for the info.
little more work than air, but still works great
every year for deer season my family generally gets around 12 deer, and we do all the processing ourselves. when we make summer sausage we genrally have over 300 lbs of meat to mix and stuff. then we have to smoke and cure it. but that doesnt take much, we have a 10x10 garden shed we made into a smokehouse and takes about 6-8 hours to smoke all of it at once.
a few years back my brother built a stuffer out of 8 inch cylinder casing. basically the stuffer is about 14 inches long with a tapped 2 inch hole on the bottom plate. we use pvc fittings for it, and have an 1 1/2" tube and a 3/4" tube. one for summer sausage and one for polish rings. but the frame for it is made out of 1" square tubing. the pusher is made out of a 3K pound trailer jack with an 8" dia. plate welded on the bottom of the jack. we use pieces of old t shirts for a gasket type thing between the meat and the pressure plate.
the only thing left is to either build or buy a mixer, which i plan on makin out of all stainless with aluminum bronze bushings so they dont ever wear out.( in my lifetime anyway)
i really wish i had a pic of it because that would help alot with the explanation of what he did for it, but i do not currently have one. if you have a question or something let me know and i will try to elaborate on it a little more.sigpic
Miller Trailblazer 302
Smith Torch Outfit
Lots of Grinders
Miller Elite Autodark Hood
O'l Trusty Jackson
Originally posted by welderdude402 View Postevery year for deer season my family generally gets around 12 deer, and we do all the processing ourselves. when we make summer sausage we genrally have over 300 lbs of meat to mix and stuff. then we have to smoke and cure it. but that doesnt take much, we have a 10x10 garden shed we made into a smokehouse and takes about 6-8 hours to smoke all of it at once.
If you could get a picture that would be great. 300# of meat, WOW you guys don't screw around
Would something like this work?
Dunno how fast they move the ram
http://www.harborfreight.com/8-ton-l...ack-94562.htmlEd Conley
MM252
MM211
Passport Plus w/Spool Gun
TA185
Miller 125c Plasma 120v
O/A set
SO 2020 Bender
You can call me Bacchus
h2o sausage stuffer
try this site for a stuffer using water
http://www.bbq-brethren.com/forum/sh...ad.php?t=76875
sorry i dont have a picture of it. it is down at my dads place...and i dont know when i will get there next.
yeah, we dont mess around lol. we have walk in cooler/freezer thats about 6x10x10 that we can hang about 6 deer in or three elk or cows in and a complete butcher room with all the fixins. nice meat grinder that does i think 500 lbs/hour. you can put entire chicken quarters down the throat of that thing and it doesnt even change the sound of the motor.
sorry to start going on about the stuff we have for butchering. anyway, whenever i am down there again, i will try to remember to get a picture of it....which should be fairly soon..bow season is already 9 days in and i gotta get my ol' monster out of the case and get some monsters hangin in the cooler lol.sigpic
Smith Torch Outfit
Lots of Grinders
O'l Trusty Jackson
Originally posted by welderdude402 View Postsorry i dont have a picture of it. it is down at my dads place...and i dont know when i will get there next.
