how much the suitable thickness for my workpiece?
If you are making this weld for testing (I get that from inspection) and you have to ask what you need to use you aren't ready to be doing it.
i was running around 120A on 1/4" for welding up.
are you planing on flat or out of position ??
i think about 1/4" would be a good place to start. add a lil V and go for it.
i'm still new to stick though so better wait for one of the others to chime in before trying a piece to be tested. but it will work for practice in the mean time.
Originally posted by Chuck U&R View PostYou have arc welder set at 140A and a 2mm electrode.
You want to butt weld 2 pieces of steel together and want to know how thick they should be to get a good, 100% penetration, weld to pass inspection.
Is this correct ???
Windsom,
Did you ever increase the duty cycle of that welder?? Will you tell us how you did it - maybe post some pics. We never did hear where you were from, or you age.
ok i gotta ask ??
is this a question as to the limits of your welder ?? are you trying to find out the max thickness you can weld ?
keeping in mind multiple passes as an option its nearly limitless ...........ok maybe not limitless. but with pre-heat and multiple passes its going to be a fair sized piece of steel.
you say take it in to have it inspected........ by who ?? they would be the person to ask what thickness you should be doing if they want to inspect it they must be looking for some thing ??
we really need a bit more info to help out here.
Okay - I'll take a guess here.
Is this correct ???
i m not trying to making some, i juz want to weld the mild steel and then bring to inspection.
i want weld mild steel plate for my project, please suggest suitable workpiece thickness..thank you very much...
arc welding
butt joint
mild steel
electrode diameter 2.0mm
welding current 140A
what is the suitable thickness for my mild steel thickness?Tags: None
