Paper Towel Dispencer
  • Jigantor
    Down to the hardware and purchased a pack of "R" clips.
    Mounted the holder onto the wall and two drill holes later the paper towel holder is now ready to go.
    One less problem to think about !
    Ji
  • Jigantor
    Even better Sberry.
    How simple is that.
    I was using a piece of bent wire before I made mine.
    Ji
  • Sberry
    These are with conduit clips, a Click image for larger version
Name:	towel holder clips.jpg
ID:	508525 minnie to allow one end to be anchored and mounted to allow it to swivel and the other a one hole clip bent to hang the roll on.
  • Jigantor
    Hi Sberry,
    It does not matter how fancy they are, it is not a test, it is just showing how we have solved a problem in our workshops so we may encourage others to have a go.
    None of this stuff is that hard, but can really save some time in the workshop.
    Thanks for adding to this thread
    Ji
  • Sberry
    I have made some too, not as fancy.Click image for larger version
Name:	towel holder.jpg
  • Jigantor
    Hi Bob,
    Yes it is easy to get a good finish with ali.
    I just think of it like timber and you can use just about all the same tools.
    To cut unusual shapes in ali I use a hand scroll saw.
    Welding ali was my last problem but I have the hang of it now.
    Good luck with the side cover
    Ji
  • aametalmaster
    Great job i love working with alum too. I will be building a new side cover for my chainsaw tomorrow from alum...Bob
  • Jigantor
    Since China started buying steel the cost has gone through the roof.
    Aluminium is still more expensive but not by a mile anymore.
    Stainless steel is still pretty expensive.
    I love aluminium because you can work it like wood and it does not need painting.
    Ji
  • welder_one
    alot more expensive than mild steel... it's easy enough to find, just alot more expensive (and i am good friends with the metal sales girl...and it's still expensive)
  • Jigantor
    Is aluminium expensive or just hard to come by in the States?
    Ji
  • welder_one
    i wish i had the aluminum resources that you do... i cant afford to play around with aluminum very often
  • Jigantor
    The paper towel dispencer needs to be sanded and polished but basically it is done.
    I have to drill two small holes in the end of the tube for the locking pins but the hardware shop is shut today so that will have to wait till tomorrow.
    Pretty pleased with the result.
    Ji
  • Jigantor
    If you have a folder or pan brake like me fold up the sides, if not clamp the sides into a soft jaw vice and bend.
    Test fit the tube.
    It is starting to look like something.
    Ji
  • Jigantor
    Finding a large drill bit that was sharp I drilled the holes for the round tube.
    The hole has to be larger than the tube but not by much.
    Debur and smooth all edges with a sanding block.
    Ji
  • Jigantor
    I then clamped it into a soft jaw vise and with a trusty file removed my pencil lines.
    I did not spend to much time with this, after all ali files like wood.
    Ji
