I am thinking about making a couple reels for my welding leads after seeing what one of the welders made. I would like to hear any suggestions and tips that you guys have to offer. Thanks in advance.
Anyone make ther own welding lead reel?
Welding Reels
My Dad made a set that held over 100' and could be turning and welding at the same time He made to copper plates that was a perfect mate and interlocked together used them for 15 years than sold the truck. Work really good can make a drawling if you want.You will need a Lathe to make this kind where the kind Dave has would be easyer to make. And I'm sure works well.
Originally posted by Vernon View PostMy Dad made a set that held over 100' and could be turning and welding at the same time He made to copper plates that was a perfect mate and interlocked together used them for 15 years than sold the truck. Work really good can make a drawling if you want.You will need a Lathe to make this kind where the kind Dave has would be easyer to make. And I'm sure works well.
Hobart Mega Arc 5040DD (with built in air compressor)
MM Passport Pluswith Q-gun
O/A
sold MM 251
There are only 2 tools needed in a tool box. 1) Duct tape to fix any thing that moves that isn't supposed to. 2) WD40 to fix anything that doesn't move but should.
Originally posted by RoughneckDave View Postheres a set i made
no bearings, and they aren't hot, so it was easy to make
just plug in jumpers from machine to reels and you're ready
daveMM250
Trailblazer 250g
22a feeder
Lincoln ac/dc 225
MM200 black face
Lown 1/8x 36" power roller
Arco roto-phase model M
Vectrax 7x12 band saw
Miller spectrum 875
30a spoolgun w/wc-24
RCCS-14
welding reels
check the pictures I have of my rig under the thread. Hobart/ Miller at the lake. and you can see my reels, they are made from Alum. horseshoes. get a lot of comments about them. they are not live. have four. two for welding leads one for extension cord. and the other one I use for 200 feet of 10/3 cable so as to plug in my mig and tig welders for 220 power off of my welder. diverdownsigpic2001 Dodge Ram welding truck. Hobart champion 10.000, miller Diversion 165. miller 180 autoset with spoolgun. SIP plasma cutter. Airless plastic welder.1996 28 foot bayliner for hauling dive and welding equipment
Bob
I have a tutorial on my website which lays out the math for building the right sized reels for the amount and size of cable you want them to hold. There are also pictures on the website of my reels and reel tree mounted on my rig.
http://www.coalsmoke.com/Coalsmokes/...3A_part_1.htmlhre
homemade reel
I am in the process of building a set as we speak. Any luck and they will be finished this weekend. I built mine from some old trailer hubs I had laying around. I will try and post Picts when finishedAttached FilesLast edited by JOE WAYNE; 08-08-2012, 07:52 PM.
