Lowes Garden Cart
  • Lowes Garden Cart
    Has anyone ever modifyed or re-built the steering linkage and rear axle on one of the Lowes garden cart?
    Fab Tech
    41 views and no replies. I don't guess that anyone has. What do you plan on doing to the cart?
    Jim
      Well 106 views and still nothing. It might be a tough project I got myself into
      I’ll see what I can do
      Hope this project is not too big for me
      Fab Tech
        If you are talking about the Ackermann theory. The inside tire has a smaller radius.
        I hope I spelled his name right.
        Bob
        Edit
        Thanks, PTsideshow I knew I butchered his name.
        Last edited by Bob Miller; 06-22-2010, 07:00 PM. Reason: spelled the man's name wrong
        Millermatic 252 w/30A
        Big Blue Air Pak
        Ellis 3000 Band Saw
        Trailblazer 302 Air Pak w/ Wireless Remote
        8-RC
        XMT 350 MPa w/S-74 MPa Plus
        Millermatic 211
        Passport Plus
        Spectrum 625 X-TREME
        Lincoln SA-200 Blue Tint Red Face '63
        2-Lincoln SA-200 Red Face '68
        SA-200 Black Face '59
        SA-200 Green Lite '84
        SA-200 Green Lite '80
        SA-200 Red Face '69
        SA-200 Red Face '66
        SA-200 Green Lite '81
        '70 Black Face Round Barrel
          I guess you're talking about a four wheel steer wagon.
          I've built one for my mig when I wanted to run it over gravel. All I did was make an angle iron frame for the the bed. Then I made two pivoting axles, think of two front ends on a wagon. On one I attached the tongue. Then I attached a rod diagonally between the front and rear axles.
          The great thing about four wheel steer is you don't have to allow for tail swing or tail cut when making a corner. Properly made your wagon's rear wheel will follow in the exact path of the front one when making a turn.
          The downside of the one I built is when making a sharp turn the wagon can tip over if top heavy. But it was simple and easy to make so I did it that way knowing I had issues with tip over under some circumstances.
          Now if you're handy and can make your axles with king pins and tie rods, as on a go kart, golf cart, automobile, you can have a four wheel steer wagon that trails tricker'n than anything without the tip over issues.
          life is good
            Don't know If you are talking about one of these
            Tractor supply garden dump cart, was thinking of what can be done for other uses with the style of frame steering. I have no use for an off road/gravel welding cart. But it could work if the center of gravity is lowered.
            All the bits and pieces laid out, I did a review of that style for another site. the steering part is upper right side in this photo the draw bar is attached by pivot to the center of the control arm to each wheel. As this cart can be used to tow behind a lawn/garden tractor. The handle can be turned around for a hitch pins trailer hitch
            This is the front section of the frame,Steering assembly before being attached
            If you are looking for what the steering looks like I can go out and snap a few pic's but right now it is filled with Fruit wood being transferred form its former home to its new short life as fuel for the son's smoker
            This is the small version carries less than the 1,000 pound version, the garden flat top carts at the garden centers around here all have the same type of steering set up.
            Originally posted by Bob Miller
            If you are talking about the Acrman theory. The inside tire has a smaller radius.
            I think you may be referring to Ackermann type
            Here is the google link there are a number of illustrations that are available
            glen, If your not on the edge, your wasting space
              Intense!
              I love these posts/subjects that challenge all your engineering and welding skills. If I recall, thinking back to my erector set days, screw 'A' goes into slot 'J' and tighten gently. Don't overtighten this bolt as it will have to be removed and another support placed on the screw at a later time.
              Be sure to have sufficient air in your tires. Never leave your wagon behind your father's car. (...how many times have I told you to put your toys away when your done with them.)
                Originally posted by jerems View Post
                Never leave your wagon behind your car (father's) .
                Is the correct quote! he 's 85
                  My neighbor wanted to use mine but I said No________way. He bought the yellow one Friday; he was moving block Saturday for his wall and the front wheel hub blew out and the whole thing collapsed, way too funny, he threw a tantrum. So I thought about beefing up mine befor it happens to me .
                  http://www.lowes.com/SearchCatalogDi...=garden+cart+#
                  Fab Tech
                    I've got a different version of that same cart bought about7 years ago.......I don't think realistically you should have a problem with it.......I was using it haul logs from a gigantic tree we cut downmore than a 1000lbs at a time......thank god for ratchet straps.....and using my rider to haul it around.........never a problem with it........still have it lengthened to 8 foot long now.its my party tent permanent hauler......definitely one of the better purchases I've made.Jim
                    Welding in Crete
                    Syncrowave 350 LX
                    Millermatic 252
                    Millermatic 180 w Spoolgun
                    Miller Gold Seal 155
                    Miller Elite welding helmet
                    JD2 Tubing bender with Hydraulic conversion
                    Evolution Raptor15" SteelDry Cut Saw
                    Hypertherm Powermax 30
                    Some really cool hammers BIG and small
                      i had the cost version with metal body all that made it into a soapbox derby car for the kids
                      the cart i had was flimsy under load but a little beefing up it can be good
                      Leblond Makino mills
                      HAAS CNC SL-40 lathe
                      American Pacemaker lathe
                      wells index mill
                      hydrotel rebuilt
                      syncrowave 250
                      diversion 165
                      Miller Elite Vintage USA
