MIG Questions
  • MIG Questions
    I am taking my second class in GMAW/MIG at a local junior college. Up until now, I’ve been working, for the most part, with sheet metal. This week I started with ½” plate (each piece is approximately 8” x 8”), and I’m having difficulty making the second and third passes.
    Keep the following in mind: I’m using a Miller CP-302 welding machine, so power is not an issue. The voltage and wire speed are appropriate: the arc is stable, there’s litter spatter, and it sounds like “bacon frying.” I’m using CO2 as the shielding gas.
    The ½” plate is prepared with a Victor oxyacetylene cutting machine with a 30-degree bevel on each piece. The bevel is finished lightly with a hand grinder; a root face of approximately 3/32” is placed on each piece. The two pieces are tack welded at the back. I’m welding in the vertical position, moving up.
    I’m doing ok making the root pass; the penetration is not what I’d like, but I think that will improve with practice. As my instructor suggests, I make the root pass with a small “u” shape and that seems to work well. As stated above, my difficulty is with the following passes.
    I’d like to know the following:
    1. What pattern do you recommend for the second and third passes? (My instructor recommends what I think of as a ladder-type pattern, pausing slightly at the sides.)
    2. Given the size of the 1/2” plates and the other details provided above, what is the appropriate root opening I should maintain after tack welding the two pieces.
    Thank you for your time.
    Given your information, I would have a 3/32" to 1/8" gap.
    Pay very close attention to your root pass - you need to get this right, or you'll fail a bend test every time. Your fill & cap passes are useless without proper fusion on your root pass.
    Now, your root pass can be Vertical Up, or Vertical Down, either will work, as long as you are working with a keyhole and are ensuring good fusion to both sides.
    Fill Pass: Box weave. Kind of hard to explain but stay with me here. The basic motion will be a "U" shape that is laid on it's side, with the open ends facing towards you, and the bottom of the "U" facing the root pass. When you get the hang of it, this will give you a full, level, weld deposit that is very easy to stack another fill pass, or cap pass on top of. Start on one side of the bevel, follow bevel into root, cross over root, follow bevel back out. Repeat. Each time that you cross through the center, try to raise up 1/2 the diameter of the electrode. It will seem a little wierd at first but keep with it...Eventually, following the bevels will feel more natural, and you won't have to concentrate on the sideways "U" motion - then you will be able to concentrate on keeping your upward steps small, and having a nice tight pattern.
    Cap pass: Straight weave. Side to side motion, pausing slightly at edges as needed to ensure proper blending out of the toes of the weld. Again, each time you pass through the center, try to raise up slightly, about 1/2 the electrode diameter. Yes, it will feel like you are welding over top of the previous pass, but when you get the hang of it, your speed will actually increase because you will deposit less each time across the joint. When you are doing it correctly, you will end up with flat looking, tightly stacked weld beads, with very slight reinforcement.
    You never stated what size of wire or what setting you are using, but when I use ER70S-6 wire, .035" and I have a joint like this, a basic setting I use is 16.5 Volts and 175 IPM or so. Of course, it can be done much faster at higher settings, but for a beginner to learn, this is where I set the machine.
    Hope it helps.
    Later,
    Jason
    Later,
    Jason
      He just told you everything you need to know to do it right. Uphill with the MIG using either straight wire or fluxcored I do it exactly the same as I run 7018 uphill, and his explanation is as good as any I can give. I think he did leave out the key words though, heheh, PRACTICE, PRACTICE, PRACTICE!
      I turned my machine down to 16 volts just to see what it was like. I quickly got bored with it. I'm used to running from about 19 to 25, mostly around 23 on anything from 12 gauge on up (I do the light stuff downhill) using NR211-MP. Can't tell you the wire speed because it doesn't tell me, lol.
      Lincoln: Eagle 10,000, Weld-Pak HD, Weld-Pak 155, AC-225, LN-25 wirefeeder
      Miller: Syncrowave 250DX Tigrunner
      Westinghouse: 400+ amp AC
      ThermalArc Handy wirefeeder
      1 Harris, 3 Victor O/A rigs
      Arcair gouger
        welding technique
        It has been my experience that we as welders will typically apply a technique that works well for one process to other processes. Sometimes we get away with it and it is OK and other times we won't. What we need to remember is the deposition rates for wire feed welding are different that other processes. due to this fact we need to be concerned about lack of fusion. So running a weave pass with MIG is more difficult to get correct than just running stringer beads. Yes the weave will fill the joint faster but the lack of fusion issue is problematic. Typically if you run destructive testing on a weave pass with MIG it will crack out in the toes. Travel speed or the speed of linear movement is critical with wire feed. This is not to say that there aren't times when a weave of some size isn't appropriate. the key is applying it when it is needed and knowing when that is and what the variables are. As you go through school for welding and on through your career, practice, practice and then practice some more. I am sorry to say that technology changes and advances so quickly that sometimes the dissemination of information isn't really all that solid. We see manufacturers develop some new item and they work with it for months before the public sees it. They then try to share the information with their distribution people and that is typically a day or two if they are lucky. Then the educators will get the opportunity to see the new technology and work with it for a day or so and then off they go. The understanding of the intricacies doesn't get from the development lab to the educator as it should. It is a fact of our society today, I need the information but I only have 15 minutes to consider it before I am off to something else. To help with this there are opportunities such as the Miller roadshow where they drag that big truck around and let people try the machines and teach them how to use it. They even have classes inside that trailer to help understand it. That puts the responsibility back on the welder to take a day off of making money to go learn how to use the machine correctly. My advice is to take the time, I know it is money but inefficient operation is money also. So off the soap box, we as welders need to understand our processes to a degree where we know the ability of the process, not just the machine or the gas or the wire but how they all work together to get it right.
          MIG Questions
          I hope I'm not the only one here that takes exception to the statement about what works for one job will work for the next.... and that's what we do???
          SJMiller
            Well??
            SJMiller
            Not sure if I would say it raises to the point of "takes exception", but I would say and/or agree that each job is different. Not just the job description, but everything. Variables in electricity, differing steel properties, weather, steel temp, etc., etc. all play in the wonderful world of variables inherent to welding. This tends to be a "experience" education rather than text book. However, logging your techniques, settings and other parameters have always proven to be the best "start point" for the next similar project.
            TacMig
            We depend On:
            Miller | Esab | Lincoln | Fronius
            Baileigh | Drake | Eagle | Knuth
            Victor | Harris | Smith | Bessey
            Snap-On | Hilti | Ingersoll Rand
            Burco/Koco | Onan | BobCat
            Tracker | Infratrol | AmeriCast
            We belong to or support:
            American National Standards Institute
            American Welding Society
            The Welding Institute
            Fabricators & Manufacturing Association Int'l.
            Anderson & Co. LLC
            Metal Cr
            afters
              I think that a couple of posters missed the point diamondback was trying to make. What I read was that many of us who used stick for a long time are trying to apply the same techniques to Mig. The material disposition rates are quite different between the two processes, consequently, what may be the best procedure for stick, will not be the best procedure for Mig.
              I, like many of you, I'm sure, still follow the same basic patterns/movement that I used with stick. With Mig, I tend to move faster from shoulder to shoulder (less time in the middle) than I did with stick. Seems to have worked so far, but I guess that what diamondback is saying is that there may be a whole different procedure which will give better results.
              Guess it's never too late to teach old dogs new tricks.
              Syncrowave 250 DX Tigrunner
              Miller MM 251 w/Q300 & 30A SG
              Hobart HH187
              Dialarc 250 AC/DC
              Hypertherm PM 600 & 1250
              Wilton 7"x12" bandsaw
              More grinders than hands
                I have read diamondbacks post, and everyone is entitled to their opinion. I disagree with some of the statements made, and do not believe that the post in that much detail was warranted in response to the question, but that is MY OPINION.
                My post was in direct response to the OP's questions. When the coupons are fed through the rollers on a guided bend test, if the root weld is poor, the coupon cracks & tears & the weld fails. The OP asked for suggestions, and received them. I'll agree with Jolly Roger that the settings I outlined can be "slow" to an experienced welder, but for a newcomer learning the techniques, slower IS better. There is A LOT to concentrate on when you are just starting out. Learn the technique correctly, and the speed WILL come.
                If you want to follow diamondbacks suggestions and just run stringers go ahead. I have had no issues with running vertical up GMAW, FCAW-SS, or FCAW-DS welds using a weave pattern. I can pass NDT (X-ray & magnaflux) and guided bend tests without lack of fusion. Others experiences may vary.
                What I will read into diamondbacks post is an overall concern that with GMAW is very easy to have good appearing but structurally poor welds. I would agree strongly with that concern. I have commented to that effect numerous times on this forum.
                Sorry if I misunderstood the post. Run on sentences without paragraphing like ideas together really derails my train of thought.
                Later,
                Jason
                Later,
                Jason
                  Hey Jason,
                  Agree with your posting 100%. Also agree the the OP's question regarding technique was answered quite well.
                  Don't know if you caught it in a previous post, but seems that diamondback has just recently been hired by Miller. I think what you are seeing in his post is a degree of frustration with how information/procedures relative to new equipment is/is not getting to the field. An example would be a guy who's stick welded for 20+ years may not be taking full advantage of some of the new Mig equipment available (ie pulsing).
                  As has been discussed in detail in other posts, few tig welders (KB excepted) are really taking advantage of say the advanced features of the Dynasty 350. Most are just trying to duplicate the results they were getting with previous equipment. Some of this, I'm sure, is the result of workplace pressure to produce results (results being a billable product). Too few employers see "messing around with machine settings to see what they do" as a productive venture.
                  The auto industry is a prime example of the absolute requirement for "continuing education". The old shade tree mechanic with his dwell meter and timing light and little else is lost in today's computerized and fuel injected vehicles. Without a computer and an ECM reader he's operating in the blind. In the marine field, companies such as Brunswick have requirements for continuing education for your mechanics or you loose your certification as a recognized shop.
                  For the continued development of the welding field, I feel it's incumbent on the major manufacturers (Miller, Lincoln, Hobart, etc) to provide a means of getting new information to the field in a timely and cost effective manner. In this vein, the use of interactive tutorials and better owner's manuals may be more "cost effective" than a one or two day workshop scattered around the country.
                  Just my thoughts. Comments?
                  Hobart HH187
                  Dialarc 250 AC/DC
                    I'm not nearly qualified to comment on the techniques explained above, but i would like to add that if Miller would produce a few short "How To" videos for their web site SHOWING actual techniques and equipment features (basic to advanced) it would greatly help most of their customers. (Not animations!). As an amature who knows no one who is a professional welder, they few instances of actual welding i have seen has helped me greatly. I was suffering with aluminum TIG, then i saw a Lincoln rep at englishtown run a but weld and it helped me immensly.
                    Millermatic 175
                    Spectrum 375
                    All kinds of Smith OA gear
                      Way Off Topic....Thread is now Hi-jacked.
                      I agree 100% with both you guys. My biggest issue with the weekend welder is, and always will be, that the individual does not receive the proper training to do a proper job.
                      I welcome anyone to pick up a welding machine & try, it is a wonderful feeling to be able to take an idea from your head, and have the skills to create it with your hands.
                      Notice I said "skills".... this means time & training. For the amateur that does not wish to enter the trade, I suggest evening classes at a Vocational or Technical School. At the very least, familiarize yourself with and experienced tradesman who can "Mentor" you and guide you in the correct precedures as you learn.
                      This is where the manufacturers really drop the ball. Selling welding equipment at Home Depot,Wal-Mart, Canadian Tire, Harbour Freight, Princess Auto, etc etc gets the welders into the hands of the end user, but not instructing how to use the machines correctly.
                      I personally, would like to see the manufacturers take some responsibility for this and possibly address it in a couple of different manners:
                      1) Include a comprehensive, DVD based tutorial showing correct maintenance & set up procedures, common user problems, and basic welding procedures.
                      2) Sponsor basic welding courses at the LWS that carry their products. This both ensures the end user is using the equipment correctly, and also builds up a repore between the end user and the LWS for future upgrades???
                      Either of the above suggestions are a Win/Win in my book.
                      Everyone that wants to weld, should be able to access the equipment and be able to weld. We as an industry, have to work harder to get the end user the correct information, so that they can follow correct procedures and make SAFE welds.
                      I'm sure that there will be arguements over liability on the manufacturers part, but manufacturing, marketing, and selling low end units to entry level end users WITHOUT giving them any form of instruction, is just irresponsible, not to mention Dangerous.
                      My rant is now over.
                      Miller, the ball is in your court.....Time to step up to the plate & take a swing.
                      Hey Batter, Batter,.......
                      Later,
                      Jason
                      Later,
                      Jason
                        If any manufacturer would do this, it would be Miller.
                        Can you tell that I'm a fan?
                        Do I get brownie points?
                        XMT-300 with S-64 wire feeder.
                        Lincoln HI-FREQ modified to run XMT.
                        Esab PCM-875 plasma cutter.
                        Miller Spoolmatic-1
                        Miller PC-300 pulser
                        Miller Optima pulser
                          I hear and agree with a lot of what you say. BUT, you imply that because anyone can buy a welder then that is a bad thing...Somehow I miss the logic in your concept. Do any work around the house? So then are you a school trained_______________(fill in the blank). Matter of fact most of us on an everyday basis do things which many go to school to learn.
                          Every work on a computer?
                          Which came first, chicken or the egg. Welder or school for welding, computer repair or schools, auto mechs or schools.
                          School: I have looked at lots of welding courses. Passed on all of them. 1) They want to teach me things I don't want to know or care about knowing. 2) At nearly 62 I just want to work with my MIG welder, not spend the next 4/5 months going to school to learn what...how to torch weld, how to stack gas bottles in a warehouse.
                          What I want to know are the details, tricks of the trade as it applies to what I want to do, no more, no less.
                          I am a retired engineer who after doing software and computers for 30 years wanted to pick up a welder, a plasma cutter and other assorted tools that will find in my garage, that I use to play with my Jeep.
                          Safety...GIVE ME A FRIGGIN break. I paid a "professional, school trained welder $40 bucks to run a bead on a AC bracket on my car...a lot of money in 1978 and I took off and installed the part.
                          I did not make it even a mile down the road when the weld broke and did several hundred dollars with of damage to my car. His claim was the "weld did not break". Yes he was right, it did not. However what I learned later on was no, it did not break, it did not STICK. He welded over the engine grease. I did not know from Adam back then, but I know now and he did not prep it in spite of me asking "don't cha need to clean off that grease? "No, the welding will just burn it off"
                          Going to a welding school does NOT make you a good or a smart welder, a safe or wise welder. It does mean you were exposed to the information (maybe) and whether or not you know it and practice it today is at best questionable and at worst not likely.
                          I hired a guy who was a grad of Harvard one time and that guy was as dumb as a mud fence. Had to let him go, he just lacked good sense. One of the few folks I ever had to get rid of due to a lack of ability to do the job and I had 175 + engineers working for me at one time.
                          I use schooling as an indicator to tell me whether or not you have been exposed to the knowledge. But I don't and never have "hired degrees". I hire the man or woman based upon my gut feeling that they can do the job (I prefer NOT to hire computer science majors either), but that is just me.
                          Don
                          Scottsdale, AZ
                          www.savagesun4x4.com
                          MillerMatic 211 AS
                          Hypertherm PowerMax30
                          Bernard 300 Amp Q Gun
                          Bernard 200 Amp Q Gun
                          Milwaukee Band-saw/stand
                          10 Angle Grinders 8, 4 1/2" -2, 7"
                          DeWalt Chop Saw
                          Craftsman Twin-Blade Saw
                          12 Ton Shop Press
                          Optrel Satellite Helmet
                          Miller Elite Helmet
                            Originally posted by SavageSunJeep
                            I hear and agree with a lot of what you say.* BUT, you imply that because anyone can buy a welder then that is a bad thing...
                            No Don,
                            The average Shmoe watching OCC and Biker Buildoff that figures he can buy an entry level welder from Home Depot and start welding up a race car, or suspension for a "Low Rider" is a BAD THING...That is where the focus of my comments are. Informing all the TV & Cyber welding experts so no-one gets hurt.
                            School:* I have looked at lots of welding courses.* Passed on all of them.* 1)* They want to teach me things I don't want to know or care about knowing.* 2)* At nearly 62 I just want to work with my MIG welder, not spend the next 4/5 months going to school to learn what...how to torch weld.What I want to know are the details, tricks of the trade as it applies to what I want to do, no more, no less.
                            The purpose of teaching you to Oxy/Acetylene weld is to give you hand to eye co-ordination, and puddle control, and also to allow you to see & understand what is happening within the puddle. All core concepts to understanding Arc Welding whether it be stick welding, wire feed welding, or Tig welding. I am very sorry that learning what you are doing so you do not kill somebody is so annoying to you.
                            That is a good goal Don, and I wish that for you too. I just wish that you learn from someone to do it correctly.
                            Going to a welding school does NOT make you a good or a smart welder, a safe or wise welder.* It does mean you were exposed to the information (maybe) and whether or not you know it and practice it today is at best questionable and at worst not likely.
                            I agree with you here. Every trade has it's share of low end workers that lack the drive & pride to do every job with due care and attention. Your experience is unfortunate and not uncommon, but to colour ALL Professional Welders with the same brush is not only unfair, it shows a high level of ignorance on your part.
                            I use schooling as an indicator to tell me whether or not you have been exposed to the knowledge.* But I don't and never have "hired degrees".* I hire the man or woman based upon my gut feeling that they can do the job.
                            Don, there is nothing wrong with your selection criteria. I would suggest that you use it to find someone more experienced in welding than yourself that you trust to show you how to do things correctly and safely.
                            Re-directing back to the end of my previous post....Manufacturers should take responsibility for this shortcoming and improper use of their equipment by either supplying a DVD based tutorial for the end user, OR sponsor courses at the LWS that carry their products.
                            Everyone pushes welding equipment, no one pushes information or safety.
                            Later,
                            Jason
                            Later,
                            Jason
                              Later,
                              Jason
                              That is why there are so many of us guys on these forums, to learn.
                              Good idea, but I am sure there is some reason why they have not...
                              Don
                              Scottsdale, AZ
                              MillerMatic 211 AS
                              DeWalt Chop Saw
                              12 Ton Shop Press
                              Miller Elite Helmet
