Boat Stern Drive Repair
  • Boat Stern Drive Repair
    A buddy had a problem with his boat, the coupler between the engine and the out drive blew and took part of the stern drive bellhousing with it.
    It had some pretty good cracks, but where they occured the part was more of a scattershield than structural, which is why it received the impact.
    Had a difficult time getting to some areas to clean adequately, especially in the corner but had access to both sides to make the repair go pretty easily. A replacement part from Penta/Volvo which purchased OMC (?) was going to run $1,100.00. So I told my buddy I could fix it for $500.00 LOL I think I'll get lunch out of him???
    3/32" Pure Tungsten
    200 Amps-throttled back some
    20 CFH Argon
    1.8 PPS
    Miller Syncrowave 200
    Homemade Water Cooler
    130XP MIG
    Spectrum 375
    60 year old Logan Lathe
    Select Machine and Tool Mill
    You may find that you have to build those cracks up and grind them out several times (buttering) to get the junk out of that casting. You may also try a little preheat. Repairs look mighty cold to me. Based on the mass involved, the Sync 200 may be a little underpowered for the task at hand. 25% Helium in your argon would help increase the arc temp also.
    I wouldn't want that part leaving my shop looking like that. Just saying, that if you're going to do a job, do it right. What I'm seeing is A LOT of porosity which translates to a weak spot.
    Oh, and it looks like you just need a few more tools on your welding table.
    Syncrowave 250 DX Tigrunner
    Miller MM 251 w/Q300 & 30A SG
    Hobart HH187
    Dialarc 250 AC/DC
    Hypertherm PM 600 & 1250
    Wilton 7"x12" bandsaw
    More grinders than hands
      I wouldn't want that part leaving my shop looking like that. Just saying, that if you're going to do a job, do it right. What I'm seeing is A LOT (
      Really? I can see it better here than you can in the pics, except for pic #4 at the top and bottom the rest looks pretty solid)
      Thanks Sundown,
      If I had a shop I probably would do a better job on it
      I did preheated it with a rosebud, and also used the heat to massage the parts back closer to their original orientation. Yes there is some slight porosity at the start/stop but overall I believe it has good structural integrity.
      130XP MIG
      Spectrum 375
        nocheapgas,
        If you don't want honest opinions then you shouldn't post photos.
        You say the part is more a scattershield and not structural. That's not exactly correct. That part serves as the rear motor mount for the engine. On a casting such as that, it's almost impossible to look at it and say it doesn't need to be structural.
        What you showed in your photos was the "easy fix". What I saw attempted there was poor preparation of the crack (you just ground the surface rather than grinding down into the crack), not enough heat, and a major crater in your bead. I already mentioned the porosity from not building the base metal up before trying to do the final bead. What was done there could have been done with marine tex and would have been as strong and better looking.
        Hard to tell from the photos but there appears to be major deformation (from impact) to the side of the housing in the area of the second (major) crack. I'm not sure what the tolerances are for the Volvo unit, but that in itself would cause major problems with the Mercruiser.
        I don't see any attempt to repair the second, more drastic crack, or the crack that goes around the side of the housing. I would hope that you plan to grind the crack almost totally out rather than just grinding the surface.
        That housing may well exceed the capabilities of the Sync 200, not necessarily because of the thickness but because of the overall mass.
        I'm not trying to "pick on you" but I have been doing marine aluminum repairs for a considerable time. What I see done there is not done right.
        With that said I'll take my keyboard and leave.
        Hobart HH187
        Dialarc 250 AC/DC
          I agree about the need to grind the cracks into a Vee.
          I do aluminum wheel repairs on occasion and the first thing I do is drill a hole all the way through at each end of the crack to keep it from running. Then I grind out the crack into a deep, wide V with about a 3/32 to 1/8" gap at the bottom (I use the filler rod as a guide to gap width). I put in the root, which I make sure penetrates fully through the other side. After that, I fill up the V with however many passes it takes to fill it, making sure the cap pass fully fills at the toes and all across the middle, so I have enough meat to grind down and not have any low spots after the grinding is done, on both sides. The multiple passes also help to burn out impurities in the metal.
          The problem with just grinding the surface and not grinding out the crack into a V, then welding from both sides, is that you've still got a crack inside there. Doing the repair that way, you've covered up the crack on both sides, but the crack still exists in the middle of the wall and will come back to the surface later, eventually.
          The other problem with not grinding out the crack into a V, is that you have no way to clean the metal inside the crack. You have all that impurity, oxidation, oil, etc that has found it's way into the crack and cannot be cleaned out without grinding out the crack all the way through it's depth.
          That impurity haunts you when you try to weld up the crack. No matter how well you clean the surface and how hot you get it with the torch or pre-heat, or how many times you go back over it in the hopes of heating out the impurities, those impurities are still in there cause you can't clean them out without grinding out the crack fully.
          Millermatic175
          MillermaticPassport/Q300
          HTP MIG200
          PowCon 300SM, MK Cobramatic
          DialarcHF, Radiator-1
          Hypertherm PowerMax 380
          Purox oxy/ace
          Jackson EQC
          -F350 CrewCab 4x4
          -LoadNGo utility bed
          -Bobcat 250NT
          -PassportPlus/Q300
          -XMT304/Optima/Spoolmatic15A
          -Suitcase8RC/Q400
          -Suitcase12RC/Q300
          -Smith oxy/propane
          -Jackson EQC
            Agree....
            Sync 200 is to small for that, I have owned a sync 200 and on aluminum the real capacity is about 3/16. If I were to off repaired that I would have used my spoolgun if it would have fit in there. With that said if the parts failed thoose parts are easy found used for the 200-300 range, at most!
            Kevin
            Lincoln ranger 305g x2
            Ln25
            Miller spectrum 625
            Miller 30a spoolgun
            Wc115a
            Lincoln 210mp
            F550 imt service truck
              No, I appreciate the feedback. The repair area was ground out, I did not show a photo of that, only one that showed the initial cleaning with a 3M rolloc surface conditioning disc. I helped disassemble the boat, and I know for a fact it is not a structural part. Yes there was some remaining deformation. A casting such as this that was subjected to the impact of the engine/outdrive coupling experiencing a rapid disassembly cannot easily be brought back into the original factory specs as far as the shape. The mounting surface was unaffected, and my friend was happy to not have t ospend $1,100 to replace the part. He was unable to find a used part.
              130XP MIG
              Spectrum 375
                hey nocheepgas. I have the same feelings as the other guys looks cold and dirty. Also you shoudn't be using pure tungsten on an ac squarewave machine, use Ceriated tungsten. Its in the owners manual.
                Miller syncrowave 200 runner with coolmate 4
                and wp2025 weldcraft torch
                Miller 125c plasma cutter
                  WTF are you talking about????
                  The owners manual says pure tungsten isn't recommended for steel! He's doing aluminum.
                  Green tungsten is fine.
                  My own shop since 1981
                  Cya Frank
                    WTF am I talking about? WTF are you talking about? I never even mentioned steel. Read it again before trying to jump on someone for what they wrote without even knowing the facts. The pure tung is not ideal for aluminum on an advanced square wave machine, ceriated or lanthiated is a much better choice of tungsten if you have an advanced square wave machine welding aluminum because they carry more heat without balling on the end, and it's recommended to grind it to a modified point because it will provide better arc stability and arc starting. It is written in the "Tig Handbook" downloadable on this site under the tungstens section.
                      Nope.... YOU are the one that's wrong on this one.
                      you would be correct IF he was using an inverter machine, he's got a sync. 200.
                      I DID go to the resources tab, pulled up the owners manual for the Sync 200, & it CLEARLY states not to use pure tungsten for steel or stainless, but green is the recommended tungsten for aluminum.
                      those my friend are the facts.
                      I really don't give a **** any more, & I won't be pulled into a pissing match.
                      Threads like this are why I quit visiting this forum for several months. Looks like I need to leave again.
                      The original poster took the time to post one of his projects, gave us pictures, & all anybody did was tell him how wrong he was.
                      I'm outta here again.
                      I may check back this fall, then again I may not. You'all have fun now, ya hear.....
                      Cya Frank
                        No matter what the manual for the machine says... it is outdated if it says to use pure.
                        Miller 30-A Spoolgun
                        Miller WC-115-A
                        Miller Spectrum 300
                          I said previously that I was taking my keyboard and leaving. I did.
                          Since these comments are not directed at the OP I will add a few items.
                          While I fully agree with FK that, while not the optimal tungsten to use on a Squarewave machine (Sync 200) the pure is OK. In the owners manual, it cautions against using pure on steel and SS. In fact, it recommends the use of thoriated for steel/SS. With advances in tungsten makeup, like FK says, the lanthanated or ceriated tungstens are a better choice.
                          The comment really deals with a couple of the other posters who throw around terms and cite references without understanding what they're talking about. Maybe they should read the "whole book".
                          For clarification, the Syncrowave 200, 250, and 350 are NOT ADVANCED SQUAREWAVE MACHINES. While the squarewave technology is considerably more advanced than the older sine wave machines and do include a balance capability they still do not fall into the advanced squarewave technology category.
                          Advanced squarewave machines in the Miller lineup include the inverters (Dynasty, Maxstar, etc) machines. These machines have many features not found on a standard squarewave machine. The Dynasty machines make use of multiple waveforms, arc shaping (through the use of higher frequency), do not require constant HF to maintain an arc in AC welding because they make the transition so quickly, increased balance range, higher pulse (PPS) rates and so on.
                          Just because you may have bought your Syncrowave 200 a few months ago doesn't make it an Advanced Squarewave Machine. The technology in that machine was developed in 1975.
                          Certain posters should learn to get their facts straight before getting in whizzing contests with other posters who also may not fully understand what they're talking about.
                          Certain posters seem to like to "blow smoke" to make people think they know what they're talking about, when, in fact, all they demonstrate is a general lack of knowledge. When they throw terms around without understanding what they mean, is a perfect example.
                          Hobart HH187
                          Dialarc 250 AC/DC
                            I've found that red (2% thoriated) can be used in any mode on any machine acceptably. It is not the ideal for all situations, but it does work.
                            My flame suit is on...
                            Millermatic175
                            HTP MIG200
                            Purox oxy/ace
                            Jackson EQC
                            -F350 CrewCab 4x4
                            -Bobcat 250NT
                            -PassportPlus/Q300
                            -Suitcase8RC/Q400
                            -Suitcase12RC/Q300
                            -Smith oxy/propane
                            -Jackson EQC
                              on my sync 200
                              i use thoriated for steel
                              i use lanthanated for most aluminum
                              i use pure when i want more of a rounded wider dime stack on thicker aluminum.
                              anyway,,, this copy paste may help
                              Pure Tungsten (TP) - Green Tip - Readily forms a ball on the end. It is generally used with transformer-based power sources for AC welding of aluminum.
                              2% Thoriated Tungsten (TT2) - Red Tip - This tungsten is the most common tungsten currently being used. It is generally utilized for DC welding of steel and stainless steel and offers good overall performance. A drawback is that this tungsten has a low level radiation hazard.
                              2% Ceriated Tungsten (TC2) - Grey Tip - 2% ceriated is an excellent substitute for 2% thoriated tungsten if you are using a transformer-based power source for DC welding. This tungsten is popular for thinner materials because it requires less amperage to start. It offers a stable arc and can be used for both AC and DC welding with inverter power sources.
                              1 ½% Lanthanated Tungsten (TL2) - Gold Tip - 1½% lanthanated is also a great substitute for 2% thoriated tungsten. It offers good arc starting characteristics and longer life than 2% thoriated. It can be used for both AC and DC welding with both inverter and transformer power sources.
                              Anything you could do, I could do better.
                              I can do anything better than you!
                              Lockheed Martin
                              Armco Steel, Baltimore
                              USW local #3185
