I finally got a few days off from the rig and got some real work done on a custom bed project for a bedroom renovation. I liked the modern look of zebrawood and wanted to incorporate some metal in my design too. But zebrawood from the local hardwood lumberyard is about $30/ft. So I made my own out of plywood. The inserts for the headboard and footboard are made from stainless and copper woven together and sprayed with some clear to keep from tarnishing. Pretty pumped about it. Just have to make the side rails...when I get some more time.
Bed Project
Bed Project
MillerMatic 252
Spoolmate 200
Diversion 165
Spectrum 625 X-Treme
Dayton 6" Miter Band Saw
Delta Drill Press
Bosch 10" Table Saw
Bosch 12" Double Bevel Miter Saw
Jet 5 Ton Chain Hoist
Radnor O/A
and this heavy duty table I made
sigpicTags: None
It's stained two ways because I like to make things incredibly difficult for myself. I put an ebony paint stain on first. It seeps deep into the soft sections of the plywood for kind of a flat finish and then is glossy on the end grain of the ply. I sanded the legs down so that only the soft remained black and then put a walnut stain on to darken up the grain.MillerMatic 252
Spoolmate 200
Diversion 165
Delta Drill Press
Bosch 10" Table Saw
Radnor O/A
Nice Bed
Nice job. I like the zebra effect with light and dark wood. It looks like a sturdy mutha. This is my next project - except out of steel. 1 1/2 X 4 rectangular tubing with stretched metal for a top.Attached Files
Dang it. Now I want something like that. Oh well, there's more than just one room in my house. And a reason to buy a roller.MillerMatic 252
Spoolmate 200
Diversion 165
Delta Drill Press
Bosch 10" Table Saw
Radnor O/A
Originally posted by jerems View PostNice job. I like the zebra effect with light and dark wood. It looks like a sturdy mutha. This is my next project - except out of steel. 1 1/2 X 4 rectangular tubing with stretched metal for a top.Mike
NoogaD:
Looks like a nice project.Miller Syncrowave 200
Homemade Water Cooler
130XP MIG
Spectrum 375
60 year old Logan Lathe
Select Machine and Tool Mill
I used 16 gauge stainless and 16 oz copper. Figured anything less would be too easy to bend and burn through. It's very sturdy though.
Thanks Nocheep!MillerMatic 252
Spoolmate 200
Diversion 165
Delta Drill Press
Bosch 10" Table Saw
Radnor O/A
Originally posted by jerems View PostI like the lattice - but... how did you get all the edges smoothed out - just a whole lot of filing and emery cloth?
Also, I found that the 4 1/2" abrasive discs from Harbor Freight for about $5 last a good bit longer and don't heat up and leave residue quite as bad as the 4 1/2" Gator Grip discs from Lowe's that cost about $11.MillerMatic 252
Spoolmate 200
Diversion 165
Delta Drill Press
Bosch 10" Table Saw
Radnor O/A
