XMT-300 with S-64 wire feeder.
Lincoln HI-FREQ modified to run XMT.
Esab PCM-875 plasma cutter.
Miller Spoolmatic-1
Miller PC-300 pulser
Miller Optima pulser
Miller 251/30A spool
Syncro200
Spectrum 625
O/A
Precix 5x10 CNC Router12"Z
Standard modern lathe
horizontal 7x12 bandsaw
Roland XC540 PRO III
54" laminator
little dog
Miller Spoolmatic-1
that first pic of the "if you see me running, try and keep up" that actually comes from the world of explosives.. being a military bomb builder.. i have like 10 olive drab tshirts with those sayings on the back...
theres a sign at work that ill have to copy down and post for you guys.. youd get a kick..
