ok guys new weld. How does this one look
  • ok guys new weld. How does this one look
    I was using a lincoln weld pak, flux core wire. hows is this one? thanks
    pretty good
    don't forget to fill in that crater
      Thanks, yea i know. that was just a scrap piece that i only just welded alittle. ( didnt want to waste my wire)
        looks fine
        mm210
        maxstar 150
          anychace, just by looking does it look like it would pass a weld inspection at all?
            Not bad...But.....
            http://i177.photobucket.com/albums/w...27/myweld2.jpg
            The weld looks O.K. but it's hard to tell if you got proper penetration. Also, why didn't you weld all the way around? To help better critique your welds, I along with several other members (I'm sure) would like to know the material, material thickness, machine, amps, filler and a cut-off side view to see your penetration. Otherwise all we are looking at is a bead. However, you bead looks good but remember, looks are deceiving especially in welding!
            Good luck and hope to see some more!
            TacMig
            We depend On:
            Miller | Esab | Lincoln | Fronius
            Baileigh | Drake | Eagle | Knuth
            Victor | Harris | Smith | Bessey
            Snap-On | Hilti | Ingersoll Rand
            Burco/Koco | Onan | BobCat
            Tracker | Infratrol | AmeriCast
            We belong to or support:
            American National Standards Institute
            American Welding Society
            The Welding Institute
            Fabricators & Manufacturing Association Int'l.
            Anderson & Co. LLC
            Metal Cr
            afters
