15' drain trench project
  • 15' drain trench project
    started this last week,, i sawed this gully and grate support system out of one piece of solid concrete... it will have a 4in drain pipe at the end that will take the water about 25feet away.
    the metal for the grate will be here at the end of the week,,, so it will be a few days until i get to the building/welding of the grate,,, its going to sit right on the ledges i made.
    i used my k960 gas saw for the down cuts and a 4/12 grinder with diamond blade installed to get at the side cuts for the supports.
    its a complicated cut,,, it also has a "V" cut at the very bottom to help drain every bit of water out,,, so you dont have standing water.
    ill add more pictures after i get my steel.
    im also doing frame offs on a 65gto conv and a 53/54 chevy custom pickup right now,,, ill post some pictures of those later this week.
    Anything you could do, I could do better.
    I can do anything better than you!
    Lockheed Martin
    Armco Steel, Baltimore
    USW local #3185
    concreted the drain pipe in today
    Lockheed Martin
    USW local #3185
      I that your fence or the neighbor, i dont know if it's a good idea to have the end of the drain so close to the post.
      Other then that nice job
        i must confess, i hate the guy next door, he does nothing but complain.. so im going to give him every inch of rain water off my huge 70' driveway,, later im going to tee my gutters into the same line.
        and yes,, its his fence,, but with some careful rock placement, i will direct the water up and underneath his fence right into his yard,, as the fence is not really my primary target to wreak havoc on.
        Lockheed Martin
        USW local #3185
          With a neighbor like you I can undurstand why he'd be complaining all the time.... I'm just jocking with you.
          I'm not sure but I think you're responsible for your rain water and it has to be contain on your property or connected with the city main sewer line.
          I'm not sure. I was thinking of doing the same for my property but I was going to make the drain end in a little trench concrete lined with little rocks in it on the side of my fence and take it to the road. But somebody told me, that I might not be allowed to make my rain water cross the sidewalk, for ice build up in the spring ????
          Anyway good luck there
          Man I cant beleive you use his fence to retain your garden rocks. I would be more then complaining. "" just notice""
            his main beef with me,, is when i run my 600hp engine with no exhaust system hooked to it.
            and to answer the rest of your questions regarding codes and laws,, i have only one answer to give,
            i suffer from what experts call, antisocial personality disorder
            its symptoms are the following
            Diagnostic Criteria:
            Three or more of the following are required:
            * Failure to conform to social norms with respect to lawful behaviors as indicated by repeatedly performing acts that are grounds for arrest
            * Deceitfulness, as indicated by repeatedly lying, use of aliases, or conning others for personal profit or pleasure
            * Impulsivity or failure to plan ahead
            * Irritability and aggressiveness, as indicated by repeated physical fights or assaults
            * Reckless disregard for safety of self or others
            * Consistent irresponsibility, as indicated by repeated failure to sustain consistent work behavior or honor financial obligations
            * Lack of remorse, as indicated by being indifferent to or rationalizing having hurt, mistreated, or stolen from another
            also,, once the lady a crossed the street called me a hillbilly,, she is always yelling when i use my gas powered leaf blower to blow all the leaves and trash off of my lawn into the street,, ending up her her front yard.
            so after she complained, i went on ebay and found the most hillybilly flag i could find, stuck it up on some 6ft poles and parked it right in front of her house for over one month, i even took pictures of it,, check it out,,, its a fish flag
            Lockheed Martin
            USW local #3185
              Nice
              This all reminds me of that Richard Pryor Movie - 'Moving'
                I'm glad I live in the country
                  About the second day that POS was parked in front of my house, I'd have pitched a molotov cocktail in the back.
                  You should be ****ed glad you don't live next door to an ol snake eater. Their bag of dirty tricks is extensive.
                  A little sugar in the fuel would quiet that 600 HP engine in short order.
                  Syncrowave 250 DX Tigrunner
                  Miller MM 251 w/Q300 & 30A SG
                  Hobart HH187
                  Dialarc 250 AC/DC
                  Hypertherm PM 600 & 1250
                  Wilton 7"x12" bandsaw
                  More grinders than hands
                    I'm betting you've eaten a few of them thar snakes.
                    I got major white trash across the street, I know what you mean........
                    So you're telling me...You're not nostalgic? Then, give me another word for it......
                      that fish flag truck also has no mufflers, its my daily driver, i like to drive it around the block waking up everyone from 4-6am while throwing my mcdonalds trash out of the windows and onto their lawns.
                      you see, i also suffer from insomnia in addition to my anti social personalty disorder and just enjoy driving around at odd times during the night and early mornings.
                      Lockheed Martin
                      USW local #3185
                        Riiiiight.........
                        If I was going to do totally ridiculous, ignorant, purposefully malicious stuff as you claim to do on a regular basis...
                        I wouldn't make a habit of telling everyone on the internet about it.
                        Believe it or not, stuff like that almost always has a way of coming back on the guy that thinks he's a real hero for doing it. Do you think it actually impresses anyone here with any sense of integrity or self respect?
                        Sounds like "shock and awe" to me.
                        Why would you say so if you weren't looking for some kind of response otherwise? That, or it's mostly BS. Oh, I'm sure you'll say you don't care & that it's just the way it is, but I sure wouldn't want to be in your shoes when it does.
                        After all, there are some people in this world who put about as much value on a person's life as you have respect your neighbors. Those kind of people never usually do a lot of talking, they just do what they have to do.
                        Sounds to me like you've been lucky so far you haven't crossed paths with one of them.
                        I would stop while you're ahead.
                        The more I read, the more I smell total BS.
                        Brother.........
                          I had no idea trolls even comes on welding websites. Mostly kids writing anything they can think of, just to get a rise out of people. But here, seems like we have a full grown. Most times they were traumatize by somebody when they were young and want the world to pay for it. They are everywhere.
                          I feel for the neighbores
                          Worthless.
                            its a mental disorder, im not the one to blame
                            Lockheed Martin
                            USW local #3185
                              It all depends how you were raised. Sometimes they dont raise you they throw you around.
