I was woundering what some of u guys use to sharpen ur tung. I have a benchgrinder but i feel that the stone on it is contaminting it. i have a syn 200 ive dedicated 1 side just 4 tung. when i weld steel and i stop the tip of my tung is yellow. when i took my tig class at school i used a belt sander or the pirhanna. im also still on my 1st box of tungsten its a housebrand i got from my lws. any info is always appreciated.
tungsten ?
personally, i use a dictionary to sharpen my tongue. ohhhh... you mean tungsten! Sorry. I lost it there for a sec.
There are tons of posts on the subject. Some like a belt sander while others like a grinder. some stones or belts are dedicated purely to the tung, others arent.
I have a fairly smooth carbide stone that i use for everything and i dont notice any problems yet
sharpen your tips to a conical profile 1.5 times the dia of the electrode.
sharpen in the same direction as the length of the electrode.
slightly blunt off the point or leave sharp.
when using A/C the tip or DCEP the tip will form its own ball.
check this out.. a wealth of info! http://www.millerwelds.com/resources...ur-skills/tig/Last edited by SignWave; 11-27-2007, 09:28 PM.Will it weld? I loooove electricity!
Miller 251/30A spool
Syncro200
Spectrum 625
O/A
Precix 5x10 CNC Router12"Z
Standard modern lathe
horizontal 7x12 bandsaw
Roland XC540 PRO III
54" laminator
little dog
