Syncro200 - Gas flow problem
  • Syncro200 - Gas flow problem
    I just purchased an almost new Syncrowave200. Set it up in the shop, tried a couple practice welds and had terrible results.
    Problem : no gas flow at the torch. I verified argon is going thru the regulator and also is coming out of the hose where it attaches to the machine. When the foot pedal is depressed, no gas comes out at the torch.
    Machine is set for DCEN and all other settings are factory default. Using an air cooled torch.
    Any suggestions what I can check out before I give up and take the S200 into the pros at a Miller service center ??
    I am a beginner interested in metal sculpting. I have about 30hrs TIG experience (class time at the Crucible in Oakland).
    if all is well to the connection on the outside of the machine, then it may be the solenoid valve, the switch that controls the valve, the wiring to the valve or the switch... many different things could be going on. Might just be best to taek er in or go back to where you bought it and ask whats going on... good luck.
    Miller 251/30A spool
    Syncro200
    Spectrum 625
    O/A
    Precix 5x10 CNC Router12"Z
    Standard modern lathe
    horizontal 7x12 bandsaw
    Roland XC540 PRO III
    54" laminator
    little dog
