These are release levers inside a Winchester Clay target trap machine to keep the arm from whipping while cocking. The levers are in a gear box with automatic transmission fluid (Type F). The material is cast steel and welds very well. In the past I just build up and mill the ends back to spec. They have lasted 6 - 8 years before they wear out and stop holding the arm cocked. Recently two sets have worn out in 8 months, so I decided to ask the experts!!!
1. The sharp (machined) corners wear off to a 3/16 radius.
2. I have not chamfered or ground the edges prior to welding back up, just build up & machine.
Questions:
1. Should I grind off the corner more so there is more weld build up to get some heat into it and impurities out?
2. Is there a rule of thumb on how much weld you should have between the base material and the finish mill surface?
3. Is 309 stainless more wear resistant? The photo V-7- (3).jpg was welded by someone else. Appears to be another material, SS ? Didn't hold up!!
4. Should I be welding parallel or perpendicula to the front edge when building up?
Thanks
Jim
Questions:
Thanks
Jim
