Originally posted by WyoRoy
View Post
what's the safest way.......
Again, you're right.
BTW, this was before plastic and epoxy came to be used in water tanks. Nice rivited construction on the ends. Back then, my dad was far more worried about the unburned acetylene from the cutting flame accumulating in the old water tank. Probably the same as he would in a brand new Wal-Mart propane tank purchased in the garden aisle, as per your reference.Miller 251...sold the spoolgun to DiverBill.
Miller DialArc 250
Lincoln PrecisionTig 275
Hypertherm 900 plasma cutter
Jet 14 X 40 lathe...ditto
Logan 7" shaper
Ellis 3000 band saw
Lots of dust bunnies
I seen a guy weld a gas tank with a mig welder. he added co2 but it still caught flame http://www.youtube.com/watch?v=tD4KiQEnxwQ
and heres ai video of someone cutting a propane tank with a plasma cutter and it caught flame too.
http://www.youtube.com/watch?v=l43u8ItnjUw
if you choose the water method, airtools will prevent shock.
tanks
I have did a lot of tanks over the years, but always remember what an oldtimer told me,if you do enough of them sooner or later you will make a mistake or conditions will get right and they will kill you or cripple you.
I do not allow anyone around me when welding or cutting on fuel tanks, dont want the distraction or the chance of some one else getting hurt
Originally posted by Wicked one View PostI hear ya just making a point. You could use a zip disc if you were afraid of unburnt gasses. I noticed you have a 14x40 jet lathe. How big a piece of soilid bar can you turn on it?Last edited by WyoRoy; 05-05-2010, 09:09 PM.Miller 251...sold the spoolgun to DiverBill.
Miller DialArc 250
Logan 7" shaper
Ellis 3000 band saw
Wicked one, Do you ever weld on live gas lines.
Its done every day.
How about crawling down in a hole to weld a pipe. Gotta worry about the trench falling in.
How about climbing a ladder to weld a pipe.
How about when you have to stand on the rail of your manlift to fit between the lower pipes to weld on the pipe above.
All of those things you do can get you hurt.
Cutting open a propane tank or welding on a trucks gas tank is no more dangerouse.
Its all about procedure.
I do agree, getting advise off the internet is probably not the best choice.
However, Tanks that are full of water will never blow up unless ther'es a baffle inside at a higher point than your water fill hole.
I'd rather tell someone how to do it, Thats going to do it any way, Than for him to do it with no advise.
As much as we want to save people Darwins going to get them sooner or later.
Originally posted by Portable Welder View PostWicked one, Do you ever weld on live gas lines.
Its done every day.
procedure
This is just my 2 cents, if the guy didnt care about procedure, then why did he ask what is the safest way to do it?? it isnt like he is insisting that he do it, just asking the safest way, whether it be water, scrap it, or have someone else do it. i love reading these post and seeing how the guy that just wants to learn how to do something and it either turns into an argument or a bashfest on how stupid a guy is for having no experience and wanting to learn something!!! think about it we all started some where
Originally posted by Portable Welder View PostI do agree, getting advise off the internet is probably not the best choice.
is great for advice. Seeing threads like this is a constant
reminder that there can be more than meets the eye when
I do something - so I keep getting reinforced to give everything
the once-over a second time, take my time, and always ask "What
am I missing? Is there something I really should not be doing?
or should be doing differently?"
The attitude even spills over into the other home-shop things
I do...
So thanks for all the advice!
Frank
Originally posted by Portable Welder View PostHowever, Tanks that are full of water will never blow up unless ther'es a baffle inside at a higher point than your water fill hole.
I'll only weld a fuel tank if it has been washed out with soapy water thoughly and than very well purged first and while welding on it with argon or another inert gas.Miller syncrowave 200 runner with coolmate 4
and wp2025 weldcraft torch
Miller 125c plasma cutter
Welding a fuel "" not gas "" is safe if you do it right. You just have to make sure it is full of inert gas, plain and simple. If somebody wants to clean it with water and soap, by all means do it.
I have done many fuel tanks "" tidy tanks in the back of pickup trucks "", I dont wash them "" but that's me "". I put my air fitting on it and put in 10 psi of air in it, find my leak and mark it. Then I put the spot where my leak is as low as i can and fill slowly the tank from the top with CO2. Then I weld the leak or put a patch without a worry in the world.
I've cut a door in between a baffle in a loader fuel tank with a zipcut with 1/2 inch of fuel in it still, to fix a leak from the inside. The tank on that loader is part of the frame. I made sure it was full of CO2.
But this is not a project a inexperience hobbie welder should attempt that's for sure.
