Hello I am using a Dynasty 200 dx to do metal replacement on a car restoration (I do not own a mig which is more suited) It is very diffucult to weld in the positions needed for auto body Has anyone ever used a tig in this kind of situation dealing with less than clean steel? I have sandblasted and acid cleaned my joints before welding but I still get an oarnge deposit on my welds (which I assume is rust oxide) Is it possible to use AC Tig for steel? could it help clean the welds Thanks Mike
Tig Welding 18 Gauge steel
Originally posted by Old Sporty View PostThe orange deposit you speak of may be lack of gas. You didn't give any particulars about your settings so, this is my best guess based on some experience.
Try turning your argon up and make sure you don't have a fan on or a breeze blowing across the work surface.
If your already running from 25-30cfh on your argon, turning it up may worsen your problem. Too much gas creates a vortex effect and actually draws in atmosphere. If it were me i would clean the orange off after welding and immediately cover the area with a self etching primer. Make sure that you hit the back side if possible also. This is generally where your problems will start as time goes by."smokin' joints for 19 yrs."
A.A.S. Weld Tech.
AWS CWI 08011711
I recently started at a new shop, had to do some tig on what was quite clean steel, I personally ground it with a flap disc. could not get anything but porosity and orange brown smut. Tried on several types of steel, still no good, swithched tanks of argon and wahlah, had a bad tank of argon, I blame all errors on myself at first, but this was a first seeing bad argon. hope this helps, PaulMore Spark Today Pleasesigpic
Originally posted by paulrbrown View PostI recently started at a new shop, had to do some tig on what was quite clean steel, I personally ground it with a flap disc. could not get anything but porosity and orange brown smut. Tried on several types of steel, still no good, swithched tanks of argon and wahlah, had a bad tank of argon, I blame all errors on myself at first, but this was a first seeing bad argon. hope this helps, Paul
Come to think of it, I emptied my argon in my attempts, swapped bottles and went home disgusted. The next day I started welding on a different project i had no issues welding anymore.. I never thought to think I had bad argon. Maybe that was itFreelance Fabber
Mobile>
'01 Dodge 1ton w/deck
07 Miller Trailblazer 302g
Miller HF251-d
3hp air compressor
Spectrum 275 Extreme
Shop>
Miller Dynasty 300sd
Lincoln Migpak 180
Originally posted by Heavy D View PostTry electrode positive in this mode it will clean the metal more and I also agree with the better gas coverage idea the orange discoloration is from a lack of gas coverage about 30 cfm for less than 90 amps should be pleanty
Originally posted by crawdaddy View PostDont want to sound ignorant here but how do I set the dynasty for electrode positive for steel? Also I was using about 15cfm gas at about 30 amps.Thanks Mike
Most body shops I've been at will use MIG or O/A on older metal, I agree that TIG does a neater job but the metal has to be right.Miller Syncrowave 200
Milermatic 252
Lincoln AC/DC "Tombstone"
