Hello all - im new to this board
    Awesome
    When I see your art I see TOOL, the band. Which is a good thing.
      My 2 cents
      Hello all, I gotta put my 2 cents in, just to say hi sarahsarah, welcome, awesome metal art! Signwave, cool flower, good job and a great reason to cherish it.
      sarahsarah, I know how you feel having problems with your equip, that drives me crazy!!! I'm glad to hear it's working again
      Sorry I'm a little late on the reply, been out of town, then crazy busy. Ya'll take care!
        hi
        how did your show go?hope it was a big success
          Originally posted by sarahsarah View Post
          I work on metal sculptures in my back yard and having my first art show very soon. in fact i have to have the stuff submitted by friday. THIS FRIDAY AHH.
          (snip)
          also...is anyone else out there obsessed with cutting metal this way?mmm
          -s
          Yep, check out this gal's stuff.
          Have fun
          L*S
          http://www.millerwelds.com/education...ead.php?t=1309
            Plasma problem
            I have a 375 X-treme and for some reason, if the air pressure drops below the required level, the machine will not recognize when the pressure is back up. I finally figured out that all I need to do is turn it off and then back on-in other words, it has to re-boot.
            • #21
              Sarahsarah,
              very nice! Just can't wait to see more of your stuff!!!
              bert
              I'm not late...
              I'm just on Hawaiian Time
              • #22
                Have fun
                L*S
                Isn't weldress a dude? ...... Nice work Sarah.
                Mike
                George W. Bush was saving your butt whether you liked it or not!
                Fear is temporary, regret is forever
                HH210 with SG
                • #23
                  Mike
                  http://www.ruthard.ca/art/donmills/silhouette.html
                  • #24
                    your realy good u sould go to welding web .com
                    • #25
                      sarahsarah, i found with the 125C if you over tighten the torch parts it will not function correctly. this might have some thing to do with the problem you were having but you need to be a bit more informative as to the problem for us to really help. as for the torch problem ,just tighten it up snug but not really tight.
                      if you have lots of stuff floating around in the shop you should blow out the inside of the spec 125 every other month at least and keep it coverd when not in use. i keep all my welding equipment coverd when not in use, it makes a big difference in the amount of garbage on the inside.
                      other common problems stem from a bad ground to worn out consumables. be shore you clean off a spot for a good ground and change consumables when they need it and you should have no trouble with the 125. its a great lil plasma cutter, i just love mine. its so cool to be able to have plasma at home, just too cool.
                      thanks for the help
