I'd like to build an aquarium stand. I'm thinking of using 1 1/2"x 14ga. sq. tubing to construct a frame. I'll then cover this from in wood. There will also be a 1/2 thick plywood top to the frame. I'd like to build the frame bigger than the tank. The frame will be 48"L x 24"W x 32"H. The tank is 36"L x 18"W x 24"H and will weigh anywhere from 800lbs to 950lbs.
This is what I'm planning on:
Frame only front view
Frame, top and tank right side. front is on the left.
Does anyone have any advice or suggestions? See any obvious flaws in my plan?
Thanks!
Jason
Thanks!
Jason
