My new 175 cart with dual bottles.
  • My new 175 cart with dual bottles.
    I wasn't completely happy with the stock cart for my needs so I made my own and added a few things to it.
    Jay
    Last image.
      And in DeWalt yellow, too! VERY BEAUTIFUL!! Can you make me one for my new Passport? Pretty please?
      Do you have room to open the wirefeeder door without taking everything off the lead spooler next to it?
        Nice rig Sapper! What is that in the round holder on the front?
          Not with the cord wound up. When it is in use the cord is not wound up like that and it opens easily.
          The round holder has a container of tip dip in there.
          Also my gun is not shown because I sold it and got a killer deal on a 15' roughneck gun which is much easier to get parts locally for.
          Here is what I have on the cart.
          I used most of the old cart for the shelves and the handles but the rest is all 1" square 1/8" wall.
          The second tank is Argon for the spoolgun (RWII) in the pelican case on the bottom for doing Aluminum and the larger bottle is argoshield (25C) (20% Argon 80% Co2).
          I made it so that controls are all near eye level as well as the side panel for ease of changing rolls and working the drive rollers. Plus I plan to build a work bench very soon and I want everything at or near the same height. I also have a 15" gun and a 20" ground.
          I want to add 2 more T's near the large tank to carry all my clamps. I also plan to add a plasma to the base and a air hose reel to the bottom for connecting to the compressor with a build it air drier/filter.
          Tools that are on the cart now besides what is easy to see.
          - 4 magnetic corner clamp
          - 1 mig plyers
          - 1 12" round ******* file for cleaning the nozzle
          - 2 bessy 12" clamps
          - 2 bessy 6" clamps
          - 2 bessy 8" clamps
          - 12 butt welding clamps
          - 2 squares
          - 1 magnetic level
          - 1 magnetic angle finder
          - 3 or 4 various wire brushes
          - 3 pairs of gloves (1 pair of welding ONLY gloves)
          - 1 shade 5 goggles for grinding
          - ear plugs
          - 2 tape measures
          - 1 metal ruler
          - 2 spanners for the angle grinder
          - and LOT different grinding/cutting/flapper wheel/wire wheel/velcro sanding disks
            I like it.
            Way cool setup, Sapper. Lot of stuff with a small footprint. Well thought out and put together. And I even like the color!!!
            triggerman
            Triggerman
            Ammonia refrigeration tech
            Millermatic 180 w/Autoset
            CST-250
            HF-15 High frequency
            XR15 w/Push-Pull Gun
              mm175
              [QUOTE=sapper]Not with the cord wound up. When it is in use the cord is not wound up like that and it opens easily.
              sapper, Are you enjoying the mm175?
              Regards, Farris
              Gone But Never Forgotten!
                I'd be interested in verifying that. Do you have the percentages swapped? And then, wouldn't that be C-20?
                  Mellow Yellow
                  There will be NO misplacing that welding cart!
                  TA Arcmaster 185 w/TIG/Stick Kit
                  MM210 w/3535 Frankengun
                  MM140 w/o AS w/SM100 & CO2
                  Hobart (Miller) 625 Plasma
                  Hobart 250ci Plasma
                  Victor O/A (always ready, but bored)
                  Lincoln Patriot Autodark (freebie)
                  .45ACP Black Talons for those difficult jobs
                    [QUOTE=fyoung]
                    Regards, Farris
                    Very much so. I have a large project in the works for this summer and it should do everything I need it too and more, it has so far.
                    The design has been re-worked a bit and I just picked up the tubing on Monday. 460' of various sizes of DOM and ERW.
                      The numbers could be swapped but it is 25C what the local place here uses for MIG gas. The little bottle is Argon which they sell as TIG gas.
                      Jay
                        Hey Sapper i'm thinking about putting a 15' gun on my mm175 and am curious if you are having any feed problems and what wire size your using?
                        miller 225 bobcat
                        miller aead200le (with miller hf tig trailer mounted)
                        mm175, mm211, TA181i
                        mm252 w/30a spool gun
                        precision tig 225
                        hobart stickmate LX ac/dc
                        Speedglas 9100X & XX / Miller Digital Elite
                        hypertherm 380 & cutmaster 52
                        victor journeyman & super range
                        ridgid chop saw, kalamazoo band saw
                        steel max and evolution carbide saws
                        6 4.5" & a 20lb 9" rockwell grinders
                        case 580 backhoe (for what i can"t lift)
                        if first you don't succeed
                        trash the b#####d
                          No problems at all. I am running .035 wire that is all that I use. I also use the knurled drive rollers as well but I have a spare pair that I have yet to need to use.
