This is what this sight is about. This is relevent info. All of the answers are good. Heck I learned something (as I always should, If I listen).
Thanks to all.
sharping tungen
how sharp
The whole point to sharpening your tungsten is to reduce the cross section of the electrode. once the electrode becomes "saturated" with current the current will leave the electrode and be come the arc (Think of pinching or reducing the diameter of a hose). The arc transfers from the cross section of the electrode or the diameter. For how much to grind back I will refer you to the AWS welding handbook volume 2 8th edition page 82 where they graphically show the difference in the arc from a change in grind angle. When you do grind the finish should be as smooth as possible and ground back evenly all the way around. This will give you the best control and keep the arc coming from the point of the electrode and not the side.
Originally posted by Samurai Dave View PostIn the event you are working with Thoriated electrodes (red band of color on the end), be aware they are mildly radioactive. Many welders like them because they work great. You could probably lick them all day long with your tounge and not suffer ill effects, but grind it into a fine dust (when you are sharpening it) and breathe it and you are asking for lung cancer.
A welding instructor from a local high school recently died before his time, of lung cancer.
I've been told the dust is so heavy that it will settle-out and you will never breathe it while grinding. Then why is there grinding dust on my respirator when I take it off? For me, I do NOT buy Thoriated electrodes. Lanthinated works fine for me. Costs a little more, but how much is our health worth?
Originally posted by dabeldesign View PostChuck it into a cordless drill and sharpen it on a belt sander. Works great!
sharpen tungsten
jje I have used both the belt & hard disk for sharpening my tungs and found that you get a better point with the beltsander because it's softer and you can have better control of your tungsten as to how much of a point you need for your work. just my thoughts on this and what works for me.
If I remember correctly from the little bit of tigging I was taught. Sharpen it to look like a ball point pen cartridge and for aluminum, it should look similiar to a Q tip.
sharping
I forgot to ask how sharp does it need to be. I am going to use the drill and belt sander.
I have used a belt sander and a grinding wheel. Both work fine. I usually sharpen to 1 1/2 times the diameter or so.
I've switched to all Lanth except in .040 (can't find it). I grind with a diamond shaping wheel off E-bay, ($45). Look under "lapidary materials" I think. I love it. It produces a good clean tip and a great arc.
