I have a tig and I do not know how to use it but first thing is to sharpen the tungen. That is on mild steel, so now I would like to know if it is better to sharpen it on a grinder or on a belt sander. I am not doing a lot so I did not see the sense in buying a tungen sharper. I am just playing around with the tig. So all the help that I can get is good.
sharping tungen
Thoriated electrodes - warning
In the event you are working with Thoriated electrodes (red band of color on the end), be aware they are mildly radioactive. Many welders like them because they work great. You could probably lick them all day long with your tounge and not suffer ill effects, but grind it into a fine dust (when you are sharpening it) and breathe it and you are asking for lung cancer.
A welding instructor from a local high school recently died before his time, of lung cancer.
I've been told the dust is so heavy that it will settle-out and you will never breathe it while grinding. Then why is there grinding dust on my respirator when I take it off? For me, I do NOT buy Thoriated electrodes. Lanthinated works fine for me. Costs a little more, but how much is our health worth?Dynasty 200 DX
Coolmate 3
I've switched to all Lanth except in .040 (can't find it). I grind with a diamond shaping wheel off E-bay, ($45). Look under "lapidary materials" I think. I love it. It produces a good clean tip and a great arc.Webb's Welding and Repair LLC
MM210 w/a 3035 spoolgun
Spectrum 625
Trialbazer 302 w/HF
http://webbsweldingandrepair.com/home
Sharping tungen......Not a clue!Nick
Miller 252 Mig
Miller Cricket XL
Millermatic 150 Mig
Miller Syncrowave 200 Tig
2-O/A outfits
Jet Lathe and Mill
Jet 7x12 horz/vert band saw
DeWalt Multi Cutter metal saw
Century 50 Amp Plasma Cutter
Propane Forge
60" X 60" router/plasma table
If I remember correctly from the little bit of tigging I was taught. Sharpen it to look like a ball point pen cartridge and for aluminum, it should look similiar to a Q tip.Ken
What else is there besides welding and riding. Besides that
Miller Thunderbolt XL 300/200 AC/DC
Hobart Handler 187
Dewalt Chop Saw
4" Air Grinder
Die Grinder
Rigid Drill Press
Kellogg 10hp Air Compressor
2009 FXDC
