Welding table build
  • Welding table build
    After thinking a while on what would be an ideal table for my needs, I finally got started. Top is 4'x 7' x 1/2" plate, flattened. The slots will allow me to get a clamp on 85-90% of the table.4" x 5# C- channel will form the perimeter and cross supportsThe 3" square cut-outs are for the middle legs and will act as a receiver for my grinder, vise, and bender. Outer legs are 5 x 5 x 3/8"which I found in the scrap section of the steelyard. Too good of a deal to pass up. Brackets on legs are for the wheels. There will also be levelling feet at each leg. Should have it buttoned up this weekend. I am building it upside down and will flip it with either a chain hoist or forklift.
    Miller 350P
    Miller Econotig
    Milwaukee Dry saw
    Evolution Dry saw (for sale)
    Scotchman 350 cold saw
    7x12 bandsaw
    1910 ATW 14 x 72 lathe
    fridge full of adult beverages
    Sirius radio
    www.snpequipment.com
    callouses and burns a plentysigpic
    It looks like you are on your way to having a fine table. I like the acme thread for the levelers. Now I have a reason to keep the 4 8" long pieces that I was getting ready to toss out. Thanks for the idea.
    Nice work.
    Miller 211 A.S. and Spoolmate 100
    Stickmate LX 235 AC / 160 DC.
    Clarke 180 EN Just in case
    Spectrum 375 X-Treme.
    O/A Medium Radnor Torch, Large Victor Torch.
    Milwaukee 14" Chop Saw.
    4 x 6 Horizontal Band Saw.
    Rockworth 80 Gallon 2 Stage 16 SCFM @ 175 PSI , 15 SCFM @ 90 PSI.
    Jackson Passive shade #5 for the plasma.
    I almost forgot the Hobart XVP AD Hood.
    Projects and Misc Albums
    http://picasaweb.google.com/keesfriend Feel Free to Have a Look ( Just keep in mind I am an amateur )
      Nice.
      How did you make the cuts in the top?
      Jack Olsen
      The Garage(And its slideshow)
      The Car(And its slideshow)
        Can you tell me what the width of the slots on the top are? I'm guessing it's a standard dimension to accommodate clamps. Thanks.
        "A little bit of knowledge is a dangerous thing"
        Millermatic 135
        Milwaukee 14" Dry Cut Saw
        Milwaukee Deep Cut Band
        Fully charged fire extinguisher
          Originally posted by Jack Olsen View Post
          Nice.
          The fab shop I got the plate from laser cut it for me per my drawing
          Miller 350P
          Miller Econotig
          Milwaukee Dry saw
          7x12 bandsaw
          Sirius radio
            I will measure tonight
            Miller 350P
            Miller Econotig
            Milwaukee Dry saw
            7x12 bandsaw
            Sirius radio
              Hey Scott. Looks to be a nice welding table. I can't wait to see the P&S plaque finished.
              Nick
              Nick
              Miller 252 Mig
              Miller Cricket XL
              Millermatic 150 Mig
              Miller Syncrowave 200 Tig
              2-O/A outfits
              Jet Lathe and Mill
              Jet 7x12 horz/vert band saw
              DeWalt Multi Cutter metal saw
              Century 50 Amp Plasma Cutter
              Propane Forge
              60" X 60" router/plasma table
                looks real good so far
                  S & P, I take it the studs and nuts worked out for you?
                  Miller DialArc 250
                  Lincoln PrecisionTig 275
                  Hypertherm 900 plasma cutter
                  Jet 14 X 40 lathe...ditto
                  Logan 7" shaper
                  Ellis 3000 band saw
                  Lots of dust bunnies
                    So far so good. Soaked them in thinner and then the wire wheel and they were like new.
                    Upgrading the breaker to 100amp tonight so I can get this wrapped up this weekend.
                    Miller 350P
                    Miller Econotig
                    Milwaukee Dry saw
                    7x12 bandsaw
                    Sirius radio
                      Thats a nice looking welding table, great job.
                        The slot width is 1.25". length wise, I figured out where my supports were going to be and the throat depth of the clamps. If need be, I can also use some all-thread and other material to span 2 slots.
                        Miller 350P
                        Miller Econotig
                        Milwaukee Dry saw
                        7x12 bandsaw
                        Sirius radio
                          The table is done. Finally heard the fan kick in on the 350 as I was running pretty hot on the frame. I only did small welds and not many when I attached the top to the frame to minimize the chance of warping the top. My neighbor came by and offered to help flip it, after grabbing an end and tugging on it, he bowed out. Using the chain hoist and pallet jack, i had it turned over in about 15 minutes. Looking forward to using it
                          Miller 350P
                          Miller Econotig
                          Milwaukee Dry saw
                          7x12 bandsaw
                          Sirius radio
                            Good looking table. Nice work.
                              That is a very nice table. I also have to move or turn my stuff by myself. You would be surprised at what you can move if you think about it for awhile.
