gooseneck trailer design questions
  • gooseneck trailer design questions
    i found a great deal on some 10 c channel 15.3 lb /ft. I am thinking about useing it to make a low boy gooseneck trailer 32 ft long. I was thinking about just useing it and 3" c channel crossmembers every 18 in. with a wood deck. does this seem like it would be strong enough to hold two cars? and either 6 or 7k axles.
    First thing the 3-inch C-channel cross members should be no more than 16-inch centers if using 2 x ? wood decking.
    Caution!
      The 10-inch C-channel seems really light for a 32-foot trailer, might want to think about a truss.
      Caution!
        I'm with sonora on the "Little Lite" comment.. the 10 x 15.3 C you mentioned is what I used on my tongue. I used a 12 x 19 I beam on the main frame and put a truss under it as well.. I am running 2 12K HD Disc brake axles under mine..
        You mentioned 7k axles.. triple singles @ 3K / tire weight rating = 18K less approx 7k of trailer = 11K in cargo +/- what is on the truck springs..
        The torque tube sonora mentioned will give you a better on highway handling ..
        Here is my 42' GN it has the 1 1/2" T&G Rumber decking with the cross-members on a 12" CL:
        Steve
        Bobcat 250EFI
        Millermatic 350P
        Hypertherm 1250
        A Bunch of tools
        And a forklift to move the heavy stuff with..
        Torchmate 2x2 CNC Plasma
        It's Miller Time - Get Back To Work!
          good comments, the light comments are my concern too. but when i search gooseneck car trailers it seems most of them are made out of 8 or 10 in c channel. so now im still confused
            Don’t panic yet!
            Give us a little more information.
            You say 32-feet long, is that total length from gooseneck receiver to the back? Or 32-feet of deck? Seems as most gooseneck A-frames are 8-feet long, and with a 60 / 40 ratio, you maybe looking at around 14-feet of span on your 10-inch C channel! Two 10”x15.3# C channel with a span of 14-feet are good for 12,800-pounds. See how it would help with a little more information? And a drawing, well can’t beat a drawing!
            Changing your 3-feet span on the decking to 18-inches makes me look foolish for posting 16-inches max!
            Caution!
              What size?
              What size cars are you hauling? 2 compacts or 2 current fullsize? 70's fullsize? Are you going to ramp on the tongue or both flat after the tongue?
              Pontiac Freak
                The 32 foot deck, 40 ft overall 2 car 5 th wheel I built runs four 6" x 10.5 lb channel lengthwise, and 3" x 4.1 lb cross members doubled up every 3' approx. It has 2 7 k axles and has hauled hundreds of cars. There are companies building 32 footers with single 6 x 10.5 channel, which seems unsafe. I think your channel would work
                Voigt Precision Welding, Inc.
                Miller Dynasty 200 DX, Miller Syncrowave 250, MillerMatic 252, Hypertherm Powermax 45, Auto Arc Trailpower 8000,272+187 lb Peter Wright anvil, 120 lb Fisher-norris, and more! Buffalo drill press, Grizzly Horiz. Bandsaw, Edwards shear, Barth Shear, bantam mechanical ironworker, Hopkins fly press, Doall Bandsaw, brown and sharpe surface grinder.
                2007 Silverado 2500HD (tow vehicle)
                2000 Camaro SS (Race car)
                  10" channel main frame 82" wide 32' with 3" crossmembers 16" spacing . Go with 7k axles 95" hub face 80" spring center [6k & 7k axles price are about the same] plus you will need the extra GVWR . IT will work.
                    Two 10” x 15.3# C channel 25-feet span are good for 7,100-pounds with 1.29-inch deflection!
                    Caution!
                      I would take a look at some engineered units and copy.
                        yes, exactly, why re-engineer the mousetrap?????
                          Its just a habit for me to look at how everything is built, what the guy or trade next to me is doing and file it away for future use. I almost always look at a trailer with that kind of eye when I am standing next to one, if I see a bent bracket take a glance. When in doubt build one gage heavier, usually just a pinch over engineered designs.
                            When I first start doing this I didn't always look, I used my own thoughts. First couple trailers I built were so heavy they barely haul themselves. Now half the stuff is with tin snips and screw gun,,, ha
