210 v 210
  • 210 v 210
    I'm in the market fo a 210 mig welder and was really only considering a MM 210 or 212. Over at the Hobart site they seem to really like the HH210 and one person seemed to prefer it over Miller but I'm not sure why. Anyone have any comments?????????????
    Nick
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    Miller Syncrowave 200 Tig
    2-O/A outfits
    Jet Lathe and Mill
    Jet 7x12 horz/vert band saw
    DeWalt Multi Cutter metal saw
    Century 50 Amp Plasma Cutter
    Propane Forge
    60" X 60" router/plasma table
    when i was lookin at some of the smaller 1xx series welders they were the same with the exception of miller had a nicer gun and blue. the guy at the lws said the internals are the same just differnt cover and gun
    DYNASTY 200DX
    SPECTRUM 625
    MM 251
    BWE
      I have the Millermatic pulser, which is really a 210 with pulsed spool gun for aluminum. Had it about 5 yrs now with zero issues, same gun and all. i dont know about the Hobart, never used the 2 side by side, but in my opinion the 210 is a great machine. I think the new Miller 210 is now the 212, not sure would have to go look
      Scott
      HMW [Heavy Metal welding]
        Dan likes the arc quality of the HH, I have one too and its a great running machine. I like mine as a second but if I was working 1/4 a lot or didn't mind the few extra dollars I would get the MM, it is still a better machine but costs a little more and you can use large spools of wire in it.
          Most definitely, if my primary material was 1/4", and a fairly decent volume of it, I'd go with the MM210/212 over the lighter duty HH 210.
          Like Cary (Sberry) for my needs, I tend to view these smaller compact units as a second unit in the fleet, my primary being a 250 amp unit, don't know what that makes my MM 210. Granted for most of my work a HH 187 or HH 210 would be fine, but neither would have worked very well for when i had to butt weld together, length wise, two pieces of 1 1/2" X 3"X 39" flat bar.
          Another avantage to some maybe the fact that the MM212 has a 15' gun instead of the 10' on the Hobart. No longer length of gun available for the Hobart. Yes, the spool gun would be an option for a longer reach, but there are limitation to places were you can get the spool gun into
            same internals?
            I would question the statement that the MM and HH have the "same internals" as I have been told by several different lws sales people otherwise.
            In my mind it also makes sense since there needs to be a way to account for the price differences.
            I do know a couple of people that have older HH machines and have had circuit board issues after use for a while.
            Just my humble opinion...hope it helps..
            ~ed~
            Have you ever noticed that enough is usually too much?!
