I'm in the market fo a 210 mig welder and was really only considering a MM 210 or 212. Over at the Hobart site they seem to really like the HH210 and one person seemed to prefer it over Miller but I'm not sure why. Anyone have any comments?????????????
210 v 210
210 v 210
Nick
Miller 252 Mig
Miller Cricket XL
Millermatic 150 Mig
Miller Syncrowave 200 Tig
2-O/A outfits
Jet Lathe and Mill
Jet 7x12 horz/vert band saw
DeWalt Multi Cutter metal saw
Century 50 Amp Plasma Cutter
Propane Forge
60" X 60" router/plasma table
and check out some of my ironwork and other stuffTags: None
I have the Millermatic pulser, which is really a 210 with pulsed spool gun for aluminum. Had it about 5 yrs now with zero issues, same gun and all. i dont know about the Hobart, never used the 2 side by side, but in my opinion the 210 is a great machine.I think the new Miller 210 is now the 212, not sure would have to go look
Scott
HMW [Heavy Metal welding]
Dan likes the arc quality of the HH, I have one too and its a great running machine. I like mine as a second but if I was working 1/4 a lot or didn't mind the few extra dollars I would get the MM, it is still a better machine but costs a little more and you can use large spools of wire in it.
Originally posted by sberry View PostDan likes the arc quality of the HH, I have one too and its a great running machine. I like mine as a second but if I was working 1/4 a lot or didn't mind the few extra dollars I would get the MM, it is still a better machine but costs a little more and you can use large spools of wire in it.
Like Cary (Sberry) for my needs, I tend to view these smaller compact units as a second unit in the fleet, my primary being a 250 amp unit, don't know what that makes my MM 210.Granted for most of my work a HH 187 or HH 210 would be fine, but neither would have worked very well for when i had to butt weld together, length wise, two pieces of 1 1/2" X 3"X 39" flat bar.
Another avantage to some maybe the fact that the MM212 has a 15' gun instead of the 10' on the Hobart. No longer length of gun available for the Hobart. Yes, the spool gun would be an option for a longer reach, but there are limitation to places were you can get the spool gun intoLast edited by Danny; 11-02-2007, 10:37 AM.
same internals?
I would question the statement that the MM and HH have the "same internals" as I have been told by several different lws sales people otherwise.
In my mind it also makes sense since there needs to be a way to account for the price differences.
I do know a couple of people that have older HH machines and have had circuit board issues after use for a while.
Just my humble opinion...hope it helps..~ed~
Have you ever noticed that enough is usually too much?!
