Wheel Studs
    Originally posted by m.k.swelding View Post
    do it the easy way and drill it a size bigger then weld it in place
    thats what welders do!!!!........they like to weld.
      Originally posted by con_fuse9 View Post
      On many cars the wheel is centered by the the studs. If you allow the studs to float around you will loose that. Not sure what tolerances matter, but lets just say most hubs are machined to better than .001. .001 is the kind of runout a good set of brake rotors (which sit on top of the hub) have when bolted to the hubs.
      The bolts are heat treated. You want to mess with that?
      Anyway:
      From this page: http://www.arp-bolts.com/FAQ/Answers.html
      "To determine what drill size you need for your wheel studs, you will need to know your axle/hub material and the wheel stud knurl diameter. If your axle/hub material is cast iron/steel your drill size will be .005˝ less than the knurl diameter. If your axle/hub material is aluminum, your drill size will be .007˝ less that the knurl diameter. The Wheel Studs Section in the catalog shows the knurl diameter sizes."
      If you read the OP's original post he is using wheel studs but they are NOT being used as wheel studs.
        That's my point.........But what is he making??
        Nick
        Miller 252 Mig
        Miller Cricket XL
        Millermatic 150 Mig
        Miller Syncrowave 200 Tig
        2-O/A outfits
        Jet Lathe and Mill
        Jet 7x12 horz/vert band saw
        DeWalt Multi Cutter metal saw
        Century 50 Amp Plasma Cutter
        Propane Forge
        60" X 60" router/plasma table
          Are you making a spare tire carrier?
          I had a spare tire carrier on a travel trailer and the studs were pushed through a hole and welded onto the 1/8" plate. It was made by a trailer parts place in Indianna.
            So in a way they are being used as wheel studs, sorta'. I put a spare tire carrier on my trailer, I tacked the studs (2) on the backside in 2 or 3 places. I used mag wheel locks because the tire is just hanging out there saying "take me". They could still take it but.....at least I'm making an attempt to keep them honest.
            • #21
              I am using the studs instead of bolts, to mount the 1//4 x 4 in flat bar on top of the forks on a walkie stacker rated at 1500 lbs, to extend them 4 inches, in order to lift a 700 lb ATV onto pallet racks that are 48 inches high.
              The forks now reach all but about 3 inches across the bottom frame of the ATV and lift it alright but I want it to go all of the way across the frame.
              The extended 4 inches just makes me feel better about it.
              A material handling company suggested that it should be OK, since I'm lifting less than 1/2 of the load limit and I'm keeping the load close to the mast.
              Millermatic 211 AutoSet w/MVP
              Century 110 volt 90/110 MIG-Gone to my son, in Texas
              Victor SuperRange OA
              Milwaukee Cold Cut Saw
              Milwaukee Portable Deep Cut Bandsaw
              Milwaukee Hole Hawg
              Jet Horizontal/Vertical Bandsaw
              Jet MD-18 Mill Drill
              Orbit Drill Press
              12 Ton Floor Press
              2002 E-350 V-10:
              1983 F-150 4.9L 6
              2004 Honda ST1300
              2007 Suzuki LTA400F Quad
              1997 Suzuki DR650
