if its a 1/2" stud and you want it to stay.
17/32"( .531)
The knurl is suppost to keep it from turning. I know one guy will push em into a 1/2" hole just to make sure. Over kill.
Live Right Have Fun
XMT350 CV/CC
22A Feeder
MM175
TB302
12vs Extreme
Hypertherm PowerMax 1000
20" x 40" CNC Mills (2)
16" x 60" engine lathe
65 Ton edwards iron worker
3/16' x 24" power slip roll
16' power feed mitering bandsaw
and other fun toys
I looked at some wheel studs we have here.
There is a section right in front of the knurl that is clean.
drill the hole that size.
Live Right Have Fun
XMT350 CV/CC
22A Feeder
MM175
TB302
12vs Extreme
and other fun toys
That could possibly be the worst advice I have ever seen on this or any other forum.
Griff
why.......?
Nick
Miller 252 Mig
Miller Cricket XL
Millermatic 150 Mig
Miller Syncrowave 200 Tig
2-O/A outfits
Jet Lathe and Mill
Jet 7x12 horz/vert band saw
DeWalt Multi Cutter metal saw
Century 50 Amp Plasma Cutter
Propane Forge
60" X 60" router/plasma table
Actually I do. Does anyone even know what the OP is doing with the wheel studs. If they were talking about replacing studs on a car or trailer part I would agree welding would not be the way.
That certaintly is NOT the worst advice I've seen on this forum.
Nick
Nick
Miller 252 Mig
Miller Cricket XL
Millermatic 150 Mig
2-O/A outfits
Jet Lathe and Mill
Propane Forge
It's going thru 1/4" x 4" flat bar, not much for the knurl part to hold on to maybe 2 tacks wouldn't be a bad idea. It wouldn't hurt anything that's for sure
On many cars the wheel is centered by the the studs. If you allow the studs to float around you will loose that. Not sure what tolerances matter, but lets just say most hubs are machined to better than .001. .001 is the kind of runout a good set of brake rotors (which sit on top of the hub) have when bolted to the hubs.
The bolts are heat treated. You want to mess with that?
"To determine what drill size you need for your wheel studs, you will need to know your axle/hub material and the wheel stud knurl diameter. If your axle/hub material is cast iron/steel your drill size will be .005˝ less than the knurl diameter. If your axle/hub material is aluminum, your drill size will be .007˝ less that the knurl diameter. The Wheel Studs Section in the catalog shows the knurl diameter sizes."
Con Fuse! Miller Dynasty 350
Millermatic 350P
-Spoolmatic 30A Hypertherm PowerMax 1000G3 Miller Multimatic 200 - awesome portable MIG (and stick and TIG) Miller Maxstar 200DX - portable TIG and stick
