Originally posted by pepi
View Post
pictures of homemade welding carts
Finally finished mine, including the paint
I bought my welder about 3 weeks ago and used it to repair my elderly plow. I then decided I need some type of cart and walaa, I found this site. I looked at a lot of pics and decided to design my own. I drew it up, and its frame is built form 1x2 1/8" tubing. Got no fancy metal saws, so it was sawzall and angle grinder with cut off wheel. Anyway, what do you all think?
The one thing that I really like about my welding table is the looped gussets. They allow me to slip whatever filler I need for the job at hand.
TIG welding and CNC cutting - Mint Design
You can see some ER70S-2 filler rods at the bottom. They are still in the PVC tube, the cap is taken off and the tube with the filler is slid under the table. When the job is done I just put the filler away. The next job may have some SS or AL filler put in it's place.Thermal Arc 185TSW, Lincoln SP135+, 4-post automotive hoist, 2x media blast cabinets, 50 ton press, 80gal air compressor, 4-1/2"x6" bandsaw, 4'x4' Torchmate CNC table with plate marker, Hypertherm Powermax 65 plasma cutter, ultrasonic cleaning stations
My welding cart attempt!!
Here's my attempt at a welding cart that has about everything you need to make it convenient to store most everything welding related, I scratch built it from mostly stainless, only because I got the SS in a deal....I installed an electrical sub panel, all wired safely, to eliminate running multiple power cables across the floor, not the cheap way to do it, but it's much nicer. Power is fed from a 220V wall outlet in the garage, it splits to 110v at the cart panel enabling the use of the TIG cooler.
It also has the air line plumbed for the plasma cutter that includes a filter. I would like to have a reel for an air hose but ran out of room. Overall a really fun build. If anyone would like to see the entire build thread, you can check it out at http://the510realm.com/viewtopic.php...114&start=1395 I warn you, there are lots of pics and pages to check out![IMG][/IMG][IMG]
[/IMG][IMG]
[/IMG]
Originally posted by goichi1 View PostHere's my attempt at a welding cart that has about everything you need to make it convenient to store most everything welding related, I scratch built it from mostly stainless, only because I got the SS in a deal....I installed an electrical sub panel, all wired safely, to eliminate running multiple power cables across the floor, not the cheap way to do it, but it's much nicer. Power is fed from a 220V wall outlet in the garage, it splits to 110v at the cart panel enabling the use of the TIG cooler.
[/IMG][IMG]
[/IMG]
It mentions the air space on page 17 of the Dynasty 200 manual.Last edited by clint738; 04-15-2013, 09:23 AM.
Originally posted by clint738 View PostThe cart design looks really nice. I was wondering though, are you not concerned about the lack of air space behind the welders for air circulation? Page 19 of the 211 manual specifies 18" of space behind and in front for air flow. I believe the space requirement spec is the same for the Dynasty too, I know it is the same for my MM252.
Thanks for the insight! Rich
I'm planning a welding cart for indoor use. (Cart will Be for Tig and Stick)
When fabbing: WHAT DO YOU USE EVERY DAY?
Here's what i have come up with:
2 gas bottles
Tig Rod Can x 6 flavors
Stick Rod Can x 4 flavors
Water Cooler
Tig Accessory Box
Grinders 2
110 Outlet
Brushes
clamps
fire extinguisher
gloves 2 pr (tig, Stick)
Forklift Pockets
Framing Squares
Things to hang
Grinding Wheels
Grinders 2
stick lead
ground
pedal
pedal cord
Tig Lead
Hood
Face Shield
110 Cord
480 cord
Air Hose
Chipping hammer
3lb Sledge
Thoughts?
Too Much? Too Little?
Drawings will follow....Last edited by coronan; 04-22-2013, 10:32 AM.
