Building and outdoor wood boiler
  • Building and outdoor wood boiler
    I just finished welding the water jacket for the boiler. I had no major leaks but many pinhole leaks and i was wondering if anyone had any idea's on what i could put on the welds or in the water to stop the pinhole leaks. Thanks.
    http://www.barsproducts.com/barsleaks_products.htm
    Caution!
      x 2
      http://www.hubbabubba.com/index.aspx...ign=hubbabubba
      Steve
      Bobcat 250EFI
      Millermatic 350P
      Hypertherm 1250
      A Bunch of tools
      And a forklift to move the heavy stuff with..
      Torchmate 2x2 CNC Plasma
      It's Miller Time - Get Back To Work!
        You might want to consider V- grooving the welds out and having a professional weld it.
        You might also want to consider an unpressurized boiler if your not a pro.
        Pressurized boilers can kill if you dont do things right.
        I know a guy that had a portion of his blow up so he now runs it without pressure.
        Good luck.
          hubbabubba will just make larger bubbles, can't speak for it's holding power.
            The pinholes are called "porosity" and it means it was not welded properly.
            It needs to be ground out or cut out with a torch, properly prepared, and re-welded.
              I agree 110% with Bodybagger. They should be ground out and re-welded. Putting something in the water is not the 'right' way to fix it.
                Its a very good thing that u have the brains and the ***** to tackle a project such as a boiler. Based on whatever design you have created though, you have the potential for a very serious explosion and knowing the limits of your skill could save your life and or property. Have u installed any kind of pressure relief or is there any built in redundancy in your design. For your own safety and piece of mind, groove out and reweld or have it professionally welded.
                owner of EVOLUTION WELDING
                  These bubbles are actually a Safety-Micro-Containment-Device..
                  Once all of the water from the boiler filled the S-M-C-D's there would be no more leaks or any chances of the boiler blowing up when the heat is applied to the system...
                  Steve
                  Bobcat 250EFI
                  Millermatic 350P
                  Hypertherm 1250
                  A Bunch of tools
                    Loctite 290 (green wicking grade)
                    You can coat the inside and outside of the weld with loctite 290 as it will wick into the porosity - penetrate deep - and seal it up both air and water tight; but I would only suggest this in a maintenance capacity as a quick temporary fix on something un-pressurized. It will take boiling water temps no-problem but you throw pressure into the mix and it will blow out the weakest link.
                    You could drain it and dry out the welds by heating them up a little with a rosebud torch, then squirt on the loctite 290 and it will wick right in and seal up. Although, considering you are building something new, you should re-do it right.
                    XMT 350 w/ S-75 DXA Feeder
                    and a Bernard 300 gun
                    Optima Pulsing Pendant
                    XR-W wire feeder + Coolmate 4
                    with an XR-W Edge Gun
                    Passport Plus w/Spool Gun
                    Regular Passport
                    Trailblazer 301G w/Freak Box &
                    S-32P volt sensing wire feeder
                    Spectrum 1000 Plasma
                    Spectrum 375 Xtreme Plasma
                    Regular Spectrum 375 Plasma
                    Victor H315FC torch & accessories
                    Victor 100FC torch & accessories
                    Meco torch & accessories by Kent White
