Finding the correct angle
  • Finding the correct angle
    Im trying to build a set of ramps for a heavy duty truck to drive on. Im using 4" X 4" X 1/4 square tubing. the length is 12' and the height is 2' 6" with a 4' deck on top for the rear axles. I need to find the formula to achieve the correct angle for the incline. thank you in advance for any help.
    4'
    2' 6" █
    12'
    Millermatic® 140™
    Thunderbolt® XL 300/200 AC/DC
    Spectrum® 625
    Is this what you’re after?
    Caution!
      Delta=17 21'14"
      or the arctan of 2.5 / 8
      was my guess because it looked like the top was 4'
      otherwise it's the arctan of 2.5 / 12 = 11 46'06"
      DYNASTY 200SD
      COOLMATE 1
      MM140AS
      SPOOLMATE 100
      SPECTRUM 625 X-TREME
      SPECTRUM 125C
        With 4-foot height.
        Caution!
          I Concur with UH60LCHIEF on the Delta
          The hypotenuse for 8’ x 2’-6” would be 8’ - 3 13/16” Delta of 17 21’ 14”
          The formula is the Law of Sin
          Fab Tech
          Fab Tech
            You forgot to subtract his 4' deck from the 12' overall length.
            Miller 340A/BP
            Victor O/A torches
            Lincoln SP125
            Too many other tools to list
            03 Ram 1500
            78 GS1000
            82 GL1100 Interstate
              Or you could just snap a couple chalk lines on the shop floor & measure it.
              MM250
              Trailblazer 250g
              22a feeder
              Lincoln ac/dc 225
              MM200 black face
              Lown 1/8x 36" power roller
              Arco roto-phase model M
              Vectrax 7x12 band saw
              Miller spectrum 875
              30a spoolgun w/wc-24
              RCCS-14
                Fab Tech
                There's a whole pile of different ways to solve a trig problem. I just used ARCTAN theta (or Tan ^-1) of the ratio of the sides Opposite / adjacent, but law of sines does the trick just the same. You could use Pythagorean theorem to solve the hypotenuse and use any number of other functions as well. There's always like a million ways to skin a cat with a trig problem. Or like MMW said you could just snap a few chalk lines and break out a protractor. My calculator just happened to be sitting right there when I read it. Either way I hope that helps
                DYNASTY 200SD
                COOLMATE 1
                MM140AS
                SPOOLMATE 100
                SPECTRUM 125C
                  I was a little confused on exactly what he was trying to do! And the drawing wasn’t real clear, to me anyway.
                  http://www.analyzemath.com/Geometry_...alculator.html
                  Caution!
                    Ramps
                    Thanks for all the replies. Im trying to save to got to welding school so I can eventually answer my own questions. The ramps have to have a 4' deck for the rear axles. Purpose being that the heavy duty truck is a industrial vacuum truck that has to offload into a 25 yard roll off container.
                    Millermatic® 140™
                    Spectrum® 625
                      I find this construction calculator to come in handy for thing like this.
                      Put in the rise and the run it calculates angle and the length of the unknown.
                      http://www.sears.com/shc/s/p_10153_1...ion+calculator
                      Rick C
                        Sweet
                        On my way to Sears now!
                        Millermatic® 140™
                        Spectrum® 625
                          Is this what you’re trying to do? How are you going to brace that ramp? Then how are you going to move them, with the square tube weighing in at 12.21 pounds per foot?
                          Caution!
                            My guess is they will be sitting in one spot all the time right by the dumpster.
                            MM250
                            Trailblazer 250g
                            22a feeder
                            Lincoln ac/dc 225
                            MM200 black face
                            Miller spectrum 875
                            RCCS-14
                              ramps
                              Almost Sonora Iron. Where the incline begins it sits flush on the floor. and the bottom rail butts up to the bottom, begin point of the incline overall height is 2' 10"
                              Actually the will be able to be loaded and moved with a roll off truck. the same truck that can move the roll off containers. They will be able to slide on the rails of the roll off truck. The wench from the truck hooks on to a hook welded inbetween the incline end of the ramp. I braced the platform end where the rear axles sit with a 4'' x 4" x 1' 10" brace and a brace on the incline as well. I will post a picture tomorrow.
                              Millermatic® 140™
                              Spectrum® 625
